Switch ElroB “Lichten voor het raam” (Lights, gWoonkamer {rfxcom=“>552653.315:LIGHTING4.PT2262:Command”}
Before I added ‘.315’ nothing was send to the rfxcom device, so from the sample in earlier mentioned reference I added it and then saw the following in the log:
015-12-28 14:54:07.425 [DEBUG] [.rfxcom.internal.RFXComBinding] - Received command (item=‘ElroB’, state=‘OFF’, class=‘class org.openhab.core.library.types.OnOffType’)
2015-12-28 14:54:07.427 [DEBUG] [.rfxcom.internal.RFXComBinding] - Transmitting data: 09130008086EEC013B0000
2015-12-28 14:54:07.828 [DEBUG] [.b.r.internal.RFXComConnection] - Data received:
Raw data = 0402010800
Packet type = TRANSMITTER_MESSAGE
Seq number = 8
Sub type = UNKNOWN
Response = ACK
2015-12-28 14:54:07.831 [DEBUG] [rfxcom.internal.ResultRegistry] - Transmitter response received:
But noting happened, when I use the control (and it works) I see this:
2015-12-28 14:54:21.941 [DEBUG] [.b.r.internal.RFXComConnection] - Data received:
Raw data = 0913000B545451014B70
Packet type = LIGHTING4
Seq number = 11
Sub type = PT2262
Id = 5526533
Command = ON
Pulse = 331
2015-12-28 14:54:22.152 [DEBUG] [.b.r.internal.RFXComConnection] - Data received:
Raw data = 0913000C54555F014970
Seq number = 12
Sub type = PT2262
Id = 5526789
Command = UNKNOWN
Pulse = 329
As you can see the raw data send from openhab : Transmitting data: 09130008086EEC013B0000 is quite different from what the remote send: 0913000B545451014B70. But I haven’t got a clue on how to fix this, any suggestions are welcome
I compiled a new version which should fix the problem with lighting4 devices : Cabinet du Docteur Petelot .
For your sensor, it should work with : {rfxcom=“>SensorId.PulseLength:LIGHTING4.PT2262:Command”}
In order to define SensorId and PulseLength (often 350), you can use the RFXMngr from RFXCOM.
Can you test it and give me your feedback ? If it doesn’t work, can you send me logs from RFXMngr when you click on ON and OFF.
According to your RFXMngr logs, your sensorId is 345429 (S1-S20 in decimal). Can you test with the new binding and {rfxcom=“>345429.315:LIGHTING4.PT2262:Command”} ? If it doesn’t work please send me your openhab.log.
Hi @Speeder, it was attached to the mail I sent, must have been lost somewhere, here it is. Oops, format is not accepted, here it is converted to pdf.openhablog.pdf (58.0 KB)
Am still testing, have got 1 of 3 switches working so am trying to get a as complete as possible test (or discover why they don’t work). Am a bit distracted at the moment with the DSMR binding. As soon as I have exhausted my testing with logs, I will get back to you.
Finished my analysis (attached). In short the new binding does not work at all for any of the switches, the official 1.8.1 binding works for 1 of 3 switches. According to my analysis you are sending it to the wrong ID to the other 2:elroanalysis.pdf (29.7 KB)1 digit is different, with the new binging all the digits are different.
Hi @pensionado,
You don’t use the correct ID with the new binding. With the new one, you have to use only the 20 first bits of the RfxMngr code. For ElroA it gives 544551 as code and 345173 as Openhab ID. It explains why you got the wrong Openhab message with 1.9-snapshot binding.
