Help needed with github jar creation
Hi! I want to use this binding: GitHub - rolandmoser/org.openhab.binding.oilfox for Oilfox.
Tried creating a jar file, but without success.
Can anyone help and provide a .jar file from that project?
Thanks!
Chris
Cheers :slight_smile:
edit:
I build it for you mega.nz
@BrutalBirdie Perfect, thanks a lot! That saved my day!
Sorry, but the jar does not work. Won’t show up in my bindings.
Did you put the jar in the correct folder?
Of course. I have installed several jars manually… It shows up with the karaf command bundles:list. So it is installed correctly, but nothing furhter happens. No thing, no binding in PaperUI.
Did you check the openhab-cli if the service/binding is listed there?
Sure, as I stated above it is available there.
There have been some changes to the project. Unfortunately, the creator does not respond to my issue: jar file · Issue #3 · rolandmoser/org.openhab.binding.oilfox · GitHub
@BrutalBirdie Could you please create a new jar-file, or write me again how I can do this myself?
I will look into it.
EDIT:
@fabdoka Here you go, I uploaded the jar to my private minio
https://io.deadsec.net/backup/org.openhab.binding.oilfox.jar?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=eha%2F20200604%2F%2Fs3%2Faws4_request&X-Amz-Date=20200604T193432Z&X-Amz-Expires=604800&X-Amz-SignedHeaders=host&X-Amz-Signature=117db8fd37605157ee0f290ebc0dfddb1faa74b47c45596d53c188efaebe89e2
Many thanks for the jar file :slight_smile:
Please leave feedback if it’s in working state or not. :slight_smile:
I put your jar-file in the openhab2-addons folder with my other jar-files and restarted openhab. But unfortunately I can’t see the binding neither via the openhab-cli nor via the paper-ui.
@BrutalBirdie Do you have any idea where the fault could be?
ownership of the file is openhab:openhab?
@iway Yes, the ownership of the file is openhab:openhab
