Help needed with http bnding
I have defined one switch with the http binding:
Switch   switch_pihole_enable		  "Status"		                    <status>    (group_PiHole)   {channel="http:url:pihole:PiHole_Switch"}
Type switch : PiHole_Switch "Status [%s]" [ commandExtension="%2$s", onValue="?enable&auth=xxxx", offValue="?disable&auth=xxx" ]
So I can switch the pihole on and off.
How can I set the switch by the api to on (statues=enable) and off (status=disable) by using the json value of “status”?
  "status": "enabled",
Can you help me?
First question: What version of openHAB?
Here’s my solution:
@Bruce_Osborne Oh 3.1m3
Sorry I have not yet worked with 3.1 Milestones
