Hi @sintei & @Nicholas_Waterton,
sorry I am stupid
Iāve installed 3.2.0 as addon and tested again.
Unfortunately itās not fixed, but the output is much better than before.
Thanks for your support
/Franz
http://192.168.3.39:8001/api/v2/
returns:
"id": "uuid:19284214-b84a-4ab7-971e-83018d4f9255",
"name": "[TV] UE48J6250",
"version": "2.0.25",
"device": {
"type": "Samsung SmartTV",
"duid": "uuid:19284214-b84a-4ab7-971e-83018d4f9255",
"model": "15_HAWKM_2D",
"modelName": "UE48J6200",
"description": "Samsung DTV RCR",
"networkType": "wireless",
"ssid": "88:c3:97:c5:dc:d6",
"ip": "192.168.3.39",
"firmwareVersion": "Unknown",
"udn": "uuid:19284214-b84a-4ab7-971e-83018d4f9255",
"resolution": "1920x1080",
"countryCode": "DE",
"msfVersion": "2.0.25",
"smartHubAgreement": "true",
"wifiMac": "FC:8F:90:AC:84:55",
"developerMode": "0",
"developerIP": ""
"uri": "http://192.168.3.39:8001/api/v2/"
https://192.168.3.39:8002/api/v2/ returns
"device": {
"developerIP": ""
"uri": "https://192.168.3.39:8002/api/v2/"
if I use 8001 and WEBSOCKET as connection
2021-11-08 18:52:19.808 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(346)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
2021-11-08 18:52:19.809 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(346)] : activate method [activate] not found, ignoring
2021-11-08 18:52:19.810 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(346)] : Set implementation object for component
2021-11-08 18:52:19.812 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(346)] : Changed state from satisfied to active
2021-11-08 18:52:19.853 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Create a Samsung TV Handler for thing 'samsungtv:tv:ca54caf4b9'
2021-11-08 18:52:19.918 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Initializing Samsung TV handler for uid 'samsungtv:tv:ca54caf4b9'
2021-11-08 18:52:19.941 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Updated artModeIsSupported: false and PowerState: true
2021-11-08 18:52:19.942 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Check and create missing UPnP services
2021-11-08 18:52:19.944 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Device was NOT online
2021-11-08 18:52:19.946 [DEBUG] [rnal.service.RemoteControllerService] - 192.168.3.39: Creating a Samsung TV RemoteController service: is UPNP:false
2021-11-08 18:52:19.948 [INFO ] [rnal.service.RemoteControllerService] - 192.168.3.39: Using WebSocket interface
2021-11-08 18:52:19.957 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: openConnection()
2021-11-08 18:52:19.958 [DEBUG] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: RemoteControllerWebSocket start Client
2021-11-08 18:52:19.960 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: WebSocketClient starting
2021-11-08 18:52:19.976 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: WebSocketClient started
2021-11-08 18:52:19.978 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: connectWebSockets()
2021-11-08 18:52:19.979 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote connecting to: ws://192.168.3.39:8001/api/v2/channels/samsung.remote.control?name=b3BlbkhBQg==
2021-11-08 18:52:19.982 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@1f7f4b1[Not completed, 1 dependents]
2021-11-08 18:52:19.984 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketArt connecting to: ws://192.168.3.39:8001/api/v2/channels/com.samsung.art-app?name=b3BlbkhBQg==
2021-11-08 18:52:19.986 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@1bcacb1[Not completed, 1 dependents]
2021-11-08 18:52:19.987 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketV2 connecting to: ws://192.168.3.39:8001/api/v2?name=b3BlbkhBQg==
2021-11-08 18:52:19.990 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@a9db3d[Not completed, 1 dependents]
2021-11-08 18:52:19.991 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Start refresh task, interval=1000
2021-11-08 18:52:20.009 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote connection established: 192.168.3.39
2021-11-08 18:52:20.019 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote: onWebSocketText: {"event":"ms.channel.connect","data":{"id":"9e91fe40-40bc-11ec-8bff-772240083197","clients":[{"id":"9e91fe40-40bc-11ec-8bff-772240083197","connectTime":1636393940004,"attributes":{"name":"b3BlbkhBQg=="},"deviceName":"b3BlbkhBQg==","isHost":false}]}}
2021-11-08 18:52:20.026 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketArt connection established: 192.168.3.39
2021-11-08 18:52:20.027 [DEBUG] [tv.internal.protocol.WebSocketRemote] - Remote channel connected. Token = null
2021-11-08 18:52:20.029 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketArt: onWebSocketText: {"event":"ms.channel.connect","data":{"id":"9e92e8a0-40bc-11ec-8bff-772240083197","clients":[{"id":"9e92e8a0-40bc-11ec-8bff-772240083197","connectTime":1636393940010,"attributes":{"name":"b3BlbkhBQg=="},"deviceName":"b3BlbkhBQg==","isHost":false}]}}
2021-11-08 18:52:20.030 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote: sendCommand: {"method":"ms.channel.emit","params":{"event":"ed.installedApp.get","to":"host"}}
2021-11-08 18:52:20.032 [DEBUG] [ungtv.internal.protocol.WebSocketArt] - 192.168.3.39: Art channel connected
2021-11-08 18:52:20.041 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote: onWebSocketText: {"event":"ms.error","data":{"message":"unable to handle message : Cannot read property 'session' of null"}}
2021-11-08 18:52:20.043 [DEBUG] [tv.internal.protocol.WebSocketRemote] - WebSocketRemote Unknown event: {"event":"ms.error","data":{"message":"unable to handle message : Cannot read property 'session' of null"}}
if I use 8002 and secure Websockets:
2021-11-08 18:54:10.942 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(349)] : activate method [activate] not found, ignoring
2021-11-08 18:54:10.943 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(349)] : Set implementation object for component
2021-11-08 18:54:10.945 [DEBUG] [covery.SamsungTvDiscoveryParticipant] - bundle org.openhab.binding.samsungtv:3.2.0.202110241625 (311)[org.openhab.binding.samsungtv.internal.discovery.SamsungTvDiscoveryParticipant(349)] : Changed state from satisfied to active
2021-11-08 18:54:10.986 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Create a Samsung TV Handler for thing 'samsungtv:tv:ca54caf4b9'
2021-11-08 18:54:11.051 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Initializing Samsung TV handler for uid 'samsungtv:tv:ca54caf4b9'
2021-11-08 18:54:11.072 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Updated artModeIsSupported: false and PowerState: true
2021-11-08 18:54:11.073 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Check and create missing UPnP services
2021-11-08 18:54:11.075 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Device was NOT online
2021-11-08 18:54:11.077 [DEBUG] [rnal.service.RemoteControllerService] - 192.168.3.39: Creating a Samsung TV RemoteController service: is UPNP:false
2021-11-08 18:54:11.079 [INFO ] [rnal.service.RemoteControllerService] - 192.168.3.39: Using SecureWebSocket interface
2021-11-08 18:54:11.089 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: openConnection()
2021-11-08 18:54:11.090 [DEBUG] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: RemoteControllerWebSocket start Client
2021-11-08 18:54:11.092 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: WebSocketClient starting
2021-11-08 18:54:11.109 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: WebSocketClient started
2021-11-08 18:54:11.111 [TRACE] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: connectWebSockets()
2021-11-08 18:54:11.112 [WARN ] [l.protocol.RemoteControllerWebSocket] - 192.168.3.39: webSocketRemote connecting without Token, please accept the connection on the TV within 30 seconds
2021-11-08 18:54:11.114 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote connecting to: wss://192.168.3.39:8002/api/v2/channels/samsung.remote.control?name=b3BlbkhBQg==
2021-11-08 18:54:11.117 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@1daf535[Not completed, 1 dependents]
2021-11-08 18:54:11.118 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketArt connecting to: wss://192.168.3.39:8002/api/v2/channels/com.samsung.art-app?name=b3BlbkhBQg==
2021-11-08 18:54:11.121 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@1ce7eb9[Not completed, 1 dependents]
2021-11-08 18:54:11.122 [DEBUG] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketV2 connecting to: wss://192.168.3.39:8002/api/v2?name=b3BlbkhBQg==
2021-11-08 18:54:11.125 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: Connecting session Future: java.util.concurrent.CompletableFuture@1bead1e[Not completed, 1 dependents]
2021-11-08 18:54:11.152 [DEBUG] [tv.internal.handler.SamsungTvHandler] - 192.168.3.39: Start refresh task, interval=1000
2021-11-08 18:54:11.234 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketArt connection error
javax.net.ssl.SSLHandshakeException: Abruptly closed by peer
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:752) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:164) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
Suppressed: javax.net.ssl.SSLException: closing inbound before receiving peer's close_notify
at sun.security.ssl.Alert.createSSLException(Alert.java:133) ~[?:?]
at sun.security.ssl.Alert.createSSLException(Alert.java:117) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:336) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:292) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:283) ~[?:?]
at sun.security.ssl.SSLEngineImpl.closeInbound(SSLEngineImpl.java:733) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.closeInbound(SslConnection.java:965) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:749) ~[bundleFile:9.4.40.v20210413]
2021-11-08 18:54:11.248 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketRemote connection error
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:752) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:164) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:135) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.closeInbound(SslConnection.java:965) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:749) ~[?:?]
2021-11-08 18:54:11.318 [DEBUG] [rnal.service.RemoteControllerService] - 192.168.3.39: Connection error: Abruptly closed by peer
2021-11-08 18:54:11.278 [TRACE] [ngtv.internal.protocol.WebSocketBase] - 192.168.3.39: WebSocketV2 connection error
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:383) ~[bundleFile:9.4.40.v20210413]
