Im starting too think that this is beyond my skill and understanding at the moment i have just been running the commands and haven’t relay got a clue whats happening
Im going too push this too a back burner for now until my skill and understanding improve
So I thank you all for the help and patience on this post
Please comment still if i get new suggestion i will still try and get this running im just not seeing any progress apart from when cweitkamp posted
[22:04:08] openhabian@openHABianPi:~$ "/etc/openhab2/scripts/Kodi_rescan.sh"
-bash: /etc/openhab2/scripts/Kodi_rescan.sh: /bin/bash^M: bad interpreter: No such file or directory
[22:04:37] openhabian@openHABianPi:~$ /etc/openhab2/scripts/Kodi_rescan.sh
I don’t have the exec binding installed
i was told not too use it for this task i asked if i should create a script or use exec and ppl said just do a script
@Sharpy Saw that post - but I think it´s mostly because the syntax is strange and it´s not the best way to learn how to handle stuff/scripts in OH.
I would not know a reason, why you shouldn´t use the exec binding for tasks like this. But maybe I´m wrong and there are some disadvantages regarding limited threads or something, that I don´t know?!
can i stop it from updating automatic every 24 hours
i’m not relay after auto update as Kodi can update its library on startup
im after getting OH to update one machine so i can copy the principle for my other machines running kodi and update all at the same time after i have added/removed media
Thanks I appreciate that , I will try , my faith is still here like i say i love OH , i have already learned quite abit since starting in December i can only imagine after years hopefully scripts ,coding,building sensors
At this point i just want it too work or give a sign of progress its like im still on the start square of this task and i have devoted quite alot of time already and so have the people helping me
I will install the Binding add the thing cant hurt
This will be my first text thing file my other things are created by paper ui my items and rules are text
2018-08-02 23:19:06.090 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Test.things'
2018-08-02 23:19:06.516 [WARN ] [hab.binding.exec.handler.ExecHandler] - Couldn't transform response because transformationService of type 'REGEX' is unavailable
2018-08-02 23:19:06.224 [hingStatusInfoChangedEvent] - 'exec:command:kodidbupdate' changed from UNINITIALIZED to INITIALIZING
2018-08-02 23:19:06.240 [hingStatusInfoChangedEvent] - 'exec:command:kodidbupdate' changed from INITIALIZING to ONLINE
Yeah, try to install the regex transformation too. I think that the --data-binary part in the command is kind of , or at least handled as, a regular expression.
Info: Kodi will execute the command once, immediately after you saved the things file, so you should see if it works without the need to trigger the item.
I can confirm that this worked but you used the VideoLibrary.Clean this cleans the library changing too VideoLibrary.Scan updated the library perfectly
Kodi did run the update as soon as i saved the thing file it also ran it after i pressed the button
Just need too remove the auto part of that now so its only manual…
I removed interval part and re saved it scanned the libary again
Haha, f*ck, sry dude - you´re right. Used one of the sample codes on the kodi wiki and didn´t recognize it was the VideoLibrary.Clean - Hope I didn´t wiped you´re whole library…
I have been watching for a while now it works perfectly but it seems to be running the update db every 3 mins or so i have removed the interval ?
2018-08-02 23:21:14.393 [.ItemChannelLinkAddedEvent] - Link 'Kodi_DBUpdate-exec:command:kodidbupdate:run' has been added.
2018-08-02 23:22:40.294 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from NULL to ON
2018-08-02 23:22:40.491 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:23:01.187 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:23:44.256 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command ON
2018-08-02 23:23:44.270 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:23:44.500 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:24:09.720 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:24:10.821 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command ON
2018-08-02 23:24:10.834 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:24:11.024 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:31:17.544 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:31:59.122 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:31:59.133 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:33:39.188 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command ON
2018-08-02 23:33:39.199 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:34:02.370 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:34:15.441 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:34:15.618 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:34:18.100 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:34:20.783 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command ON
2018-08-02 23:34:20.794 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:34:21.015 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:34:25.569 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:34:53.666 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:34:53.890 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:35:28.391 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command ON
2018-08-02 23:35:28.414 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:35:28.626 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:38:30.672 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:38:30.861 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:39:30.863 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:39:31.066 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:40:31.072 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:40:31.281 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:41:31.290 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:41:31.504 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:42:31.515 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:42:31.753 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:43:31.768 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:43:32.005 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:44:32.015 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:44:32.301 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:45:32.274 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:45:32.525 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:46:32.546 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:46:32.753 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:47:32.774 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:47:47.193 [ome.event.ItemCommandEvent] - Item 'Kodi_DBUpdate' received command OFF
2018-08-02 23:47:47.201 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:48:53.525 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:48:53.720 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:49:53.742 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:49:53.984 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
2018-08-02 23:50:53.999 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from OFF to ON
2018-08-02 23:50:54.218 [vent.ItemStateChangedEvent] - Kodi_DBUpdate changed from ON to OFF
took that as a base for the exec command and trying around a bit - and this is definitely one of the downsides using the exec binding: the syntax. But after a few minutes, there was success.
The will to digg into some stuff and understand what you´re doing, is the key to success.
