I am trying to set up a siren. I set up a switch to turn it on and off but I can’t change the parameters. Here is the manual that came with it: http://www.gocontrol.com/manuals/WA105DBZ-Install.pdf and here is one that matches the model number on the device: http://ipathome.be/Data/Vision/ZM%201601-5%20Siren_20150602_Vision.pdf Both of the manuals seem to line up with the xml database http://cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/108?layout=openhab1
Here are the items I have set up:
Switch Alarm_Siren "Siren" <siren> {zwave="14:command=switch_binary,respond_to_basic=true" }
Number Mode_Siren "Siren Mode" <siren> { zwave="14:command=configuration, parameter=0" }
Number Time_Siren "Siren Auto Stop" <siren> { zwave="14:command=configuration, parameter=1" }
The switch works but not the configuration parameters when I try to set them to 0, 1 or 2
In HABmin it comes up as “Linear [ID:503,Type:2005]” and the configuration parameters are not available.
Any help would be appreciated.
