Is there anyone that could elaborate on the installation of arping on a windows machine?
I’ve been trying to get arping by Thomas Habets to work, as it is mentioned in the network binding docs. But i’m way down a rabbit hole of installing libraries to install other libraries to compile arping using Cygwin. It feels like this is the wrong direction.
The arping.exe offered by Thomas doesn’t run as it has missing dlls probably due to its age. And links on his site to windows instructions go to dead links now.
Any help would be appreciated, and i’m sure that other windows users will be wanting to install arping, as the network binding looks great for presence detection.
I’ve been struggling with this too. Having managed to get z-wave security, squeezbox and and so many other fiddly bindings working, its been quite frustrating.
Has anyone managed to get arping to run on windows?
If so, what was the source of a working arping.exe?
What gets entered in paperui - the best i can get is it to say that "arping cannot be found at ‘.’ " whatever path I put in.
In case anyone still needs this: I got the arping.exe starting without error from Thomas Habets on Windows 10 with following dlls: (you will find them on dll-files.com).
Packet.dll Version 4.1.0.2001 32Bit
wpcap.dll Version 3.1.0.23 32Bit
Unfortunately I get an additional error if I try to run the ping.
arping: libnet_init(): D:\archive\packages\netutils\libnet\src\libnet_link_win32.c(): unable to open the driver, error Code : 14
seems like installation issue. doesn anyone here have successfully ran arping on win10 without issues?
Is there 64 bit arping version for win10? If yes, give it a shot.
