Help with a simple Rule to wait 5 seconds
Hi All
hoping for some help
I currently have the below rule running that turns a group of lights off when the house alarms is set only when its dark, however every so often the alarm seems to send send a false signal for 1 second then returns back to off/unset however this then stars the rule and turns the group of lights off.
My question is can it be changed so the rule will wait for maybe 5 seconds of the state change to stay set/on before running and if its changes back in less then 5 seconds/ it would cancel or not do anything
rule "Alarmset"
    Item F2_AlarmSet changed
    if(F2_AlarmSet.state == ON && SunElevation.state < 0 ) {
  gHome.sendCommand(ON)
thank you for anyone who can help what i have tried has failed
You’re looking for timers, per the documentation.
“plusMinutes” can be “plusSeconds” (or other units of time).
See Design Pattern: Motion Sensor Timer
so i have this
rule "Alarmset"
if(timer === null) {
        timer = createTimer(now.plusSeconds(30)) [|
          timer = null]}
all i have achieved is a 30sec delay regardless if the state changes back within the 30sec, could you point me to what i have missed.
am sorry i am still learning
You have to cancel the timer if it exists and the AlarmSet changes to OFF.
if(F2_AlarmSet.state == OFF) {
    timer?.cancel
else if(F2_AlarmSet.state == ON && ...
Thank you this makes sense
