I am getting the following error message in my log throughout the day. I think its coming from astro binding, but I’m not sure. I am using OpenHAB 1.8 and the astro binding is also 1.8. Any help would be appreciated.
2016-01-25 12:11:24.159 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2016-01-25T12:11:24.134-05:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@8de31c (explicitSyntax: true) threw an unhandled Exception:
java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:67) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor135.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:657) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor144.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
at com.sun.proxy.$Proxy86.apply(Unknown Source) ~[na:na]
at org.openhab.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:44) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) ~[quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
2016-01-25 12:11:24.187 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2016-01-25T12:11:24.134-05:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: org.eclipse.xtext.xbase.impl.XClosureImplCustom@8de31c (explicitSyntax: true) threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:224) ~[quartz-all-2.1.7.jar:na]
Caused by: java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
... 1 common frames omitted
