Hi everyone i’m having some problems with my setup after following a fix for a different problem
My original problem was with the marketplace the fix was too download two .jar files and stick them in a certain folder after rebooting my setup i was faced with two different errors
hoping for some pointers here
post with original problem
2018-09-30 23:11:43.842 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=31, bundle=4/mvn:org.ops4j.pax.url/pax-url-aether/2.5.4]: Unexpected problem updating configuration org.ops4j.pax.url.mvn
java.lang.ExceptionInInitializerError: null
at javax.crypto.JceSecurityManager.<clinit>(JceSecurityManager.java:65) ~[?:?]
at javax.crypto.Cipher.getConfiguredPermission(Cipher.java:2587) ~[?:?]
at javax.crypto.Cipher.getMaxAllowedKeyLength(Cipher.java:2611) ~[?:?]
at sun.security.ssl.CipherSuite$BulkCipher.isUnlimited(CipherSuite.java:535) ~[?:?]
at sun.security.ssl.CipherSuite$BulkCipher.<init>(CipherSuite.java:507) ~[?:?]
at sun.security.ssl.CipherSuite.<clinit>(CipherSuite.java:614) ~[?:?]
at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(SSLContextImpl.java:294) ~[?:?]
at sun.security.ssl.SSLContextImpl.access$100(SSLContextImpl.java:42) ~[?:?]
at sun.security.ssl.SSLContextImpl$AbstractTLSContext.<clinit>(SSLContextImpl.java:425) ~[?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:264) ~[?:?]
at java.security.Provider$Service.getImplClass(Provider.java:1634) ~[?:?]
at java.security.Provider$Service.newInstance(Provider.java:1592) ~[?:?]
at sun.security.jca.GetInstance.getInstance(GetInstance.java:236) ~[?:?]
at sun.security.jca.GetInstance.getInstance(GetInstance.java:164) ~[?:?]
at javax.net.ssl.SSLContext.getInstance(SSLContext.java:156) ~[?:?]
at shaded.org.apache.http.conn.ssl.SSLContextBuilder.build(SSLContextBuilder.java:162) ~[?:?]
at org.ops4j.pax.url.mvn.internal.HttpClients.createConnManager(HttpClients.java:75) ~[?:?]
at org.ops4j.pax.url.mvn.internal.HttpClients.createClient(HttpClients.java:47) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.<init>(AetherBasedResolver.java:164) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.<init>(AetherBasedResolver.java:154) ~[?:?]
at org.ops4j.pax.url.mvn.internal.Activator.updated(Activator.java:178) ~[?:?]
at org.ops4j.pax.url.mvn.internal.Activator$OptionalConfigAdminHelper$1.updated(Activator.java:266) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) ~[8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [8:org.apache.felix.configadmin:1.8.16]
Caused by: java.lang.SecurityException: Can not initialize cryptographic mechanism
at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:93) ~[?:?]
... 31 more
Caused by: java.security.PrivilegedActionException
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:82) ~[?:?]
... 31 more
Caused by: java.io.FileNotFoundException: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/security/US_export_policy.jar (Permission denied)
at java.util.zip.ZipFile.open(Native Method) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:225) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:155) ~[?:?]
at java.util.jar.JarFile.<init>(JarFile.java:166) ~[?:?]
at java.util.jar.JarFile.<init>(JarFile.java:130) ~[?:?]
at javax.crypto.JceSecurity.loadPolicies(JceSecurity.java:353) ~[?:?]
at javax.crypto.JceSecurity.setupJurisdictionPolicies(JceSecurity.java:323) ~[?:?]
at javax.crypto.JceSecurity.access$000(JceSecurity.java:50) ~[?:?]
at javax.crypto.JceSecurity$1.run(JceSecurity.java:85) ~[?:?]
... 31 more
2018-09-30 23:11:50.314 [ERROR] [org.openhab.ui.homebuilder ] - [org.openhab.homebuilder(11)] The activate method has thrown an exception
java.lang.NoClassDefFoundError: Could not initialize class sun.security.ssl.SSLContextImpl$TLSContext
at org.eclipse.jetty.util.ssl.SslContextFactory.load(SslContextFactory.java:306) ~[?:?]
at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:221) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[?:?]
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131) ~[?:?]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:113) ~[?:?]
at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:72) ~[?:?]
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:268) ~[?:?]
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81) ~[?:?]
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235) ~[?:?]
at org.eclipse.jetty.server.Server.doStart(Server.java:401) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl$1.start(JettyServerImpl.java:350) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:250) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerResources(HttpServiceStarted.java:299) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerResources(HttpServiceProxy.java:72) ~[?:?]
at org.openhab.ui.homebuilder.internal.HomeBuilderDashboardTile.activate(HomeBuilderDashboardTile.java:33) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.updateController(Activator.java:352) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.lambda$scheduleUpdateFactory$2(Activator.java:291) ~[?:?]
2018-09-30 23:11:50.497 [ERROR] [er.internal.HomeBuilderDashboardTile] - Error during Home Builder startup: alias: '/homebuilder' is already in use in this or another context
2018-09-30 23:11:52.024 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/London'.
2018-09-30 23:11:52.043 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_GB'.
2018-09-30 23:11:52.047 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SIUnits'.
2018-09-30 23:11:53.668 [ERROR] [io.socket.thread.EventThread ] - Task threw exception
java.lang.NoClassDefFoundError: sun.security.ssl.SSLContextImpl$CustomizedTLSContext
at javax.net.ssl.SSLContext.getDefault(SSLContext.java:96) ~[?:?]
at javax.net.ssl.SSLSocketFactory.getDefault(SSLSocketFactory.java:122) ~[?:?]
at javax.net.ssl.HttpsURLConnection.getDefaultSSLSocketFactory(HttpsURLConnection.java:332) ~[?:?]
at javax.net.ssl.HttpsURLConnection.<init>(HttpsURLConnection.java:289) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.<init>(HttpsURLConnectionImpl.java:94) ~[?:?]
at sun.net.www.protocol.https.Handler.openConnection(Handler.java:62) ~[?:?]
at sun.net.www.protocol.https.Handler.openConnection(Handler.java:57) ~[?:?]
at java.net.URL.openConnection(URL.java:979) ~[?:?]
at io.socket.engineio.client.transports.PollingXHR$Request.create(PollingXHR.java:166) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.transports.PollingXHR.doPoll(PollingXHR.java:129) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.transports.Polling.poll(Polling.java:95) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.transports.Polling.doOpen(Polling.java:35) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.Transport$1.run(Transport.java:82) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.thread.EventThread.exec(EventThread.java:55) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.Transport.open(Transport.java:77) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.Socket$2.run(Socket.java:248) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.engineio.client.Socket.open(Socket.java:226) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.client.Manager$1.run(Manager.java:330) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.client.Manager.open(Manager.java:250) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.client.Manager.open(Manager.java:240) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.client.Socket$3.run(Socket.java:133) ~[222:org.openhab.io.openhabcloud:2.3.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [222:org.openhab.io.openhabcloud:2.3.0]
2018-09-30 23:11:53.943 [ERROR] [org.openhab.ui.dashboard ] - [org.openhab.dashboard(31)] The activate method has thrown an exception
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:105) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:221) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:205) ~[?:?]
at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerServlet(HttpServiceProxy.java:65) ~[?:?]
at org.openhab.ui.dashboard.internal.DashboardService.activate(DashboardService.java:78) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [39:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [39:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-09-30 23:11:54.081 [WARN ] [org.openhab.ui.dashboard ] - FrameworkEvent WARNING - org.openhab.ui.dashboard
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
