I need some help configuring hysteresis on an item. I have a channel containing an illuminance value from the weatherflowsmartweather binding and I would like to use hysteresis to set a switch that will control landscape lights.
However the switch item is not being populated (it shows “Err” in the sitemap) and the log shows the following warning. I’ve tried multiple formats for the lower= and upper= parameters without success.
[ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value 'ON' of item LandscapeAutomation with format '%.1f %unit%': Conversion = 'u'
Thing
UID: weatherflowsmartweather:tempest:HB-00148563:ST-00145952
label: Tempest Sensor
thingTypeUID: weatherflowsmartweather:tempest
configuration: {}
bridgeUID: weatherflowsmartweather:hub:HB-00148563
channels:
- id: illuminance
channelTypeUID: weatherflowsmartweather:illuminance
label: Illuminance
description: Illuminance
configuration: {}
Item:
Switch LandscapeAutomation "Landscape Automation {channel="weatherflowsmartweather:tempest:HB-00148563:ST-00145952:illuminance" [profile="system:hysteresis", lower="1000 lx", upper="4000 lx", inverted="true"]}
Does anyone have any suggestions to help resolve this?
Thank you.
Jim
- Platform information:
- Hardware: Synology DS1821+
- OS: DSM 7.1
- openHAB version: 4.1.3 running in Docker
