Sharpy
(Aaron Sharp)
1
Hi everyone hoping for a hint or two
I have been working on my sitemap adding items that change colours depending on the state of the item most of these have worked ok
- I have been trying too get my temp item too change colour but couldent get it too work i have tried a few variations
Sitemap Item
Group item=Ghousetemp label="House Temp" valuecolor=[>=25°C="red",<=20°C="green",<=15°C="blue"]
Log Update
2018-07-29 20:38:56.854 [GroupItemStateChangedEvent] - Ghousetemp changed from 21.04 to 21.05 through Toilet_Temp
Item
Group:Number:AVG Ghousetemp "Temperature Group [%d °C]" <temperature>
- Also My Sensor Batterys MIN item is a group item
Group item=Gbattery label="Sensor Batterys MIN [%s %%]" valuecolor=[>75="green",<50="orange",<5="red"]
when i open the group the items contained dont have the colour coding is there a way too change this ?
vzorglub
(Vincent Regaud)
2
Change the order, from the smallest to the largest:
Group item=Gbattery label="Sensor Batterys MIN [%s %%]" valuecolor=[<5="red",<50="orange",>75="green"]
Sharpy
(Aaron Sharp)
3
Hi Vincent thanks for the reply
I have just swapped it around was my mistake just read the docs and realized the order matters
any ideas on how too solve my temperature item or add colours too the group item ?
vzorglub
(Vincent Regaud)
4
Group item=Ghousetemp label="House Temp" valuecolor=[<=15="blue",<=20="green",>=25="red"]
But there is no color between 20 and 25
Sharpy
(Aaron Sharp)
5
is there a way too add color
i was after between 15 and 25 green as this is a good temp above 25 red hot below 15 blue cold ?
vzorglub
(Vincent Regaud)
6
Group item=Ghousetemp label="House Temp" valuecolor=[<=15="blue",<25="green",>=25="red"]
Sharpy
(Aaron Sharp)
7
That solved my temperature item thanks for that
is it possible too add it too the items inside a group?
vzorglub
(Vincent Regaud)
8
You’ll have to define the items in the sitemap one by one, I am afraid
Sharpy
(Aaron Sharp)
9
I thought that might be the case that’s not a problem tho tbh
Thanks for your help on that
