Using OH 4.0.3 and openhab-js 4.5.1
Slowly porting rules from Jython and its progressed extremely smoothly until now. I’d like to compare a luminance value from a zwave item to a threshold value (currently 300 lx).
This is the rule:
rules.JSRule({
name: "Master Bathroom Heat Lamp Is On",
description: "Master Bathroom Heat Lamp Is On", tags: ["TEST1", "TEST2"], id: "MasterBathroomHeatLampOn",
triggers: [triggers.ItemStateChangeTrigger("Sensor2_luminance"), triggers.ItemCommandTrigger("Test_Switch_1")],
execute: (event) => {
console.info (utils.OPENHAB_JS_VERSION);
console.log (`-------------------------------------------------------------------`);
console.log (`RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [${items.getItem("Sensor2_luminance").state}]`);
var reportedLuminance = items.Sensor2_luminance.quantityState;
var thresholdLuminance = Quantity('300 lx');
console.log (`RULE: Master Bathroom Heat Lamp Is On | Luminance value: [${reportedLuminance}] | threshold value: [${thresholdLuminance}].`);
if (reportedLuminance < thresholdLuminance) {
console.log (`RULE: Master Bathroom Heat Lamp Is On | Luminance value [${reportedLuminance}] is less than threshold: [${thresholdLuminance}]`);
else if (reportedLuminance >= thresholdLuminance) {
console.log (`RULE: Master Bathroom Heat Lamp Is On | Luminance value [${reportedLuminance}] exceeds threshold: [${thresholdLuminance}]`);
the output for some values is correctly calculated:
openhab:send Sensor2_luminance 20 lx
22:31:56.790 [INFO ] [hab.automation.script.file.xxxtest.js] - 4.5.1
22:31:56.793 [INFO ] [hab.automation.script.file.xxxtest.js] - -------------------------------------------------------------------
22:31:56.797 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [20 lx]
22:31:56.800 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value: [20 lx] | threshold value: [300 lx].
22:31:56.808 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value [20 lx] is less than threshold: [300 lx]
however, where a luminanceValue starts with the first number of the threshold value, it seems to start giving the wrong calculation. For a threshold value of 300 the calculation tells me that 31 lx is greater than 300lx. If I change the threshold value to 400 anything less than 41 is ok, but from 41 onwards it tells me its higher):
openhab:send Sensor2_luminance 31 lx
22:34:26.527 [INFO ] [hab.automation.script.file.xxxtest.js] - 4.5.1
22:34:26.529 [INFO ] [hab.automation.script.file.xxxtest.js] - -------------------------------------------------------------------
22:34:26.530 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [31 lx]
22:34:26.533 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value: [31 lx] | threshold value: [300 lx].
22:34:26.536 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value [31 lx] exceeds threshold: [300 lx]
The item definition is currently:
Number:Illuminance Sensor2_luminance "Luminance [%d]" (gBathroomSensor) { channel="zwave:device:24d480e0:node11:sensor_luminance", homekit="LightSensor, LightSensor.LightSensor"}
but i’ve tried with %unit% in the description and also { unit = "lx" } in the channel.
Using .numericState and comparing the threshold as a number (eg 300) avoids the problem, however I was hoping to work with the UoM as best practice (and also understand how it all works).
I thought that it might be because I’m sending updating the value manually however I let the item update naturally and got some wacky results:
23:08:39.764 [INFO ] [hab.automation.script.file.xxxtest.js] - 4.5.1
23:08:39.766 [INFO ] [hab.automation.script.file.xxxtest.js] - --------------------------------------------------------------------
23:08:39.768 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [1708 lx]
23:08:39.770 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value: [1708 lx] | threshold value: [300 lx].
23:08:39.773 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value [1708 lx] is less than threshold: [300 lx]
23:09:40.157 [INFO ] [hab.automation.script.file.xxxtest.js] - 4.5.1
23:09:40.160 [INFO ] [hab.automation.script.file.xxxtest.js] - --------------------------------------------------------------------
23:09:40.163 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [3 lx]
23:09:40.168 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value: [3 lx] | threshold value: [300 lx].
23:09:40.172 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value [3 lx] is less than threshold: [300 lx]
23:10:40.139 [INFO ] [hab.automation.script.file.xxxtest.js] - 4.5.1
23:10:40.141 [INFO ] [hab.automation.script.file.xxxtest.js] - --------------------------------------------------------------------
23:10:40.143 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance state value is: [4 lx]
23:10:40.146 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value: [4 lx] | threshold value: [300 lx].
23:10:40.147 [INFO ] [hab.automation.script.file.xxxtest.js] - RULE: Master Bathroom Heat Lamp Is On | Luminance value [4 lx] exceeds threshold: [300 lx]
I’m sure its something simple I’m doing wrong but I just can’t work it out. Help is greatly appreciated.
EDIT: Just realised that the error occurs also with a single digit so if the luminanceValue is 4 and the thresholdValue is 300, then I also get “exceeds”.
