Hello all,
I’m having a hard time making a Leviton Vizia RF+ Fan Control to work with my ZWave network (NODE 20). I am getting lots of errors related to NODES 19 and 20 in the log file. In Habmin, the node is grey. Not sure what it means…
NODE 20 : Leviton VIZIA RF+ Fan Control (ID:209, Type 1001).
NODE 19: Evolve Wall Switch (ID:3533, Type 5257)
There is no XML file created for node 20. All other nodes are working, node 19 has an xml file.
Not sure what is wrong. Am I declaring there correctly in .items file?
Anything that can be obtained from the partial log below?
Thanks a lot !
Eric
Item file:
Switch Socket_10 “Outdoor Lights” (Outdoor,Lights) { zwave=“19” }
Dimmer CeilingFan “Fan [%d %%]” (GF_MusicRoom, Lights) { zwave=“20:command=SWITCH_MULTILEVEL,refresh_interval=600”}
Log:
2016-05-24 21:40:12.678 [INFO ] [rialApiGetInitDataMessageClass] - NODE 14: Node found
2016-05-24 21:40:12.680 [INFO ] [rialApiGetInitDataMessageClass] - NODE 16: Node found
2016-05-24 21:40:12.681 [INFO ] [rialApiGetInitDataMessageClass] - NODE 17: Node found
2016-05-24 21:40:12.683 [INFO ] [rialApiGetInitDataMessageClass] - NODE 18: Node found
2016-05-24 21:40:12.684 [INFO ] [rialApiGetInitDataMessageClass] - NODE 19: Node found
2016-05-24 21:40:12.686 [INFO ] [rialApiGetInitDataMessageClass] - NODE 20: Node found
2016-05-24 21:40:12.688 [INFO ] [rialApiGetInitDataMessageClass] - NODE 21: Node found
2016-05-24 21:40:12.691 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2016-05-24 21:40:12.693 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2016-05-24 21:40:12.695 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2016-05-24 21:40:12.697 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 12
2016-05-24 21:40:12.699 [INFO ] [rialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2016-05-24 21:40:14.153 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 20: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-24 21:40:14.518 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 19: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-24 21:40:19.505 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:40:23.912 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 19: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-24 21:40:24.232 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 19: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-24 21:40:30.647 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:40:37.573 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:40:39.946 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 20: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-24 21:40:39.953 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 20: Unknown command class 0x91
2016-05-24 21:40:39.957 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 20: Unsupported command class POWERLEVEL
2016-05-24 21:40:44.966 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:40:49.977 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:40:54.988 [ERROR] [WaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:40:59.993 [WARN ] [WaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 14
2016-05-24 21:41:04.998 [WARN ] [WaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 14
2016-05-24 21:41:10.002 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:41:10.025 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:15.031 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:41:15.555 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:20.560 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:41:20.569 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:25.575 [WARN ] [WaveController$ZWaveSendThread] - NODE 20: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 14 02 72 04
2016-05-24 21:41:30.586 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:41:30.593 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:35.599 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:41:35.630 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:40.634 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:41:40.813 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:45.818 [WARN ] [WaveController$ZWaveSendThread] - NODE 20: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 14 02 72 04
2016-05-24 21:41:50.827 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:41:50.834 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:41:55.840 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:41:55.848 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:00.854 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:42:00.863 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:05.868 [WARN ] [WaveController$ZWaveSendThread] - NODE 20: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 14 02 72 04
2016-05-24 21:42:10.881 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:42:10.893 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:15.898 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:42:17.464 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:22.469 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:42:22.471 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:27.476 [WARN ] [WaveController$ZWaveSendThread] - NODE 20: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 14 02 72 04
2016-05-24 21:42:32.482 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:42:32.485 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:37.493 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 1 attempts left!
2016-05-24 21:42:37.500 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:42.506 [ERROR] [WaveController$ZWaveSendThread] - NODE 20: Timeout while sending message. Requeueing - 0 attempts left!
2016-05-24 21:42:42.508 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 20: Got an error while sending data. Resending message.
2016-05-24 21:42:47.518 [WARN ] [WaveController$ZWaveSendThread] - NODE 20: Too many retries. Discarding message: Message: class = SendData (0x13), type = Request (0x00), payload = 14 02 72 04
2016-05-24 21:42:54.009 [ERROR] [WaveController$ZWaveSendThread] - NODE 16: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-24 21:42:54.016 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 16: Got an error while sending data. Resending message.
2016-05-24 21:42:54.593
