Hi David…
Thanks for the insight! At times I thought I was mixing it, but I have to be honest - I found it very confusing to differentiate what type configuration belonged to what binding, or even what binding I have? I assume since I have OpenHAB2 and it came with it, it’s version 2? I definitely have no problem with OpenHAB with the multiple methods of configuration, I think it provides good flexibility. I came from 1.7, and still actually prefer to set those up manually - I find it more comfortable to integrate into the sitemap, although I do have to admit the autodetect was easy!
Honestly the whole MiLight/LimitlessLED/whateverthe@$$$namethisthingismarketedunder is confusing. 3 hardware bridge versions, 2 ibox versions, old led’s new led’s use this if you have this bridge, this bulb wont work with that… I can certainly see why the binding is such a challenge.
I currently have 2 sets - 1 bridge (gold sticker) and 1 ibox1, both with a set of Warm White and 1 set of RGBWW.
I tried first with the bridge and the RGBWW set and this is what I got working.
I wasnt successful in getting the ibox to auto detect yet even so its on the network.
These sets are also on 2 different OpenHAB installations in 2 different locations, so they are not interferring.
Thanks for everyones input!
