I configure modbus TCP, and want to manage my bassein with openhab. I can read registers, but little bit struggle with writing, and transformation. i have this attached file from vendor, and want to see it and manage in openhab.
Maybe someone help me, how to convert unsigned int16 to bits, and read/write them?
I’ve written a guide on bitwise working with openHAB and Modbus.
Reading individual bits is straightforward. Start with something simple like a read only register.
Writing bits is complicated - that’s due to how Modbus works, not openHAB.
Using individual bits in registers is an odd design choice, given that Modbus provides a way to address individual bits anyway. But we have to work with what we’ve got.
I’m a bit worried about the talk of “pulse” in the chart you have shown us. Are these bits you have to turn on and then turn off again?
Okay, well if you are patient we can work something out. What can we try for simple experiments, “Light” perhaps?
First though, have a try at setting up Modbus poller and items/channels for that read-only status register (20?). Getting a “Pool Opened” Item working might be rewarding
I would recommend using xxx.things files for this, because this will get complicated. And xxx.items files, because I expect we shall make use of the version 1.x expire binding.
Its fine to use PaperUI for anything else, but it is difficult to get an overview of many channels like we will need here.
Obviously bit masks are not really that odd a design choice given it’s the most efficient way to store a set of boolean values.
Would MODBus providing individual bit access not require additional programming of the MODBus layer to implement such a feature in the particular instance? It may have firmware overheads, complexity overheads, storage overheads etc. Also with the bits being stored in a 16 bit register they can be read together in one read, rather than individually reading 16 different boolean values.
That said, reading, updating and then writing a 16 bit register to update a single bit field opens you to race conditions and I don’t believe MODBus supports transactions or locking (could be wrong). This is something the OP needs to be aware of when updating these values that he is sure there will only be one single threaded device writing to these values or they could be corrupted in race conditions.
Having worked a little at the hardware level you will find that things are done VERY differently that you would expect looking at it from a high level software perspective. With something like MODBus being primarily a hardware interface layer/protocol it is not unexpected to find some of the hardware weirdness to leak though.
Modbus protocol natively supports reading and writing of single bits as “coil” and “discrete” 1-bit registers. It was specifically designed in the 1970s to support general binary actions like “heater on” without fuss.
But as I said, it’s a designer decision and we must work with what we got.
The key is to “OR” the 16 bit int with another 16 bit int with only the correct bit set to 1. Bits being 1, 2, 4, 8, 16, 32 etc.
EDIT: To determine if a bit IS set of not, then you AND the 16 bit with another 16 bit which has that bit (and only that bit) set to 1. eg:
10011
AND
10000
Will give you
10000
So in the form of pysedo code above:
FIELD_03_06 = modbus.read( address )
IF FIELD_03_06 &= COMMAND_OPENPOOL == COMMAND_OPENPOOL
COMMAND_OPEN_POOL is active
Did you see this? It is a linked thread, if you click on it there is more detail.
I am prepared to help you with this, but I’m not going to write it all for you.
Please have a try at reading that status register into openHAB Items, and let us know how you get on. We will help. This is complicated, but if we go step by step there is a path to make it work.
My point was more about how things differ at the hardware level. Put simple, while you may often find an IC that provides you ModBUS interface layer and you just write stuff to it and flash a definition of your registers to it, these things vary a lot. ( I have not used an MODBus interface IC specifically).
A high level software person would, usually, just install “lib_modbus” and be done with it, but if you design has a Microcontroller with only 4K of RAM that is probably not an option. So “fudges” or partial implementations of interface layers are very common.
i know, how to manipulate with bits. for me is clear OR, AND, XOR… my question is from where to start.
i can read int16 into openhab2 variable. for example I read 16 address into variable, and see 1…
means for me in16=1, bit 0 is set to 1, means filtration is enabled.
but how to use transformation??? what i need to put into modbus data objects? i install transformation plugin, but not sure, how to use it.
how I can get my 16 boolean varibles from than int16??? and then how to write them back to modbus. I do not need full help, i just need to understand how to start
I find PaperUI rather clumsy when you need to look at a lot of Items, channels, Things, at the same time.
PaperUI does not allow you to link Items to version 1.x bindings either. I think we will find the expire binding useful for making ‘pulses’, and that happens to still be version 1.x
So instead, we can set up Items and Things using text files.
Obviously, you will need some kind of text editor for that. Almost certainly you will also want (or already have) use a text editor to customise your sitemap for BasicUI? What are you using for that?
When you come to make rules (and we will need rules here), assuming you want to use the standard rules language (“DSL”), you will need some text editor for that as well.
Sitemaps live in a folder something like openhab2/conf/sitemaps. There are also 'sister" folders ../conf/items , ../conf//things , ../conf/rules which should be fairly self explanatory?
With all this text file editing going on, I would recommend using VSCode editor with the openHAB extension - it will do syntax checking etc.
I’m afraid that would be something else new to learn, but will probably save time in the long run over using a simple text editor.
Please read and understand the post I linked to about using Modbus for bitwise.
It does not involve any transformations, you cannot force a transformation to do what you want.
It uses the Modbus binding’s bitwise addressing feature to “split out” bits from a register into separate channels that can be linked to separate Items.
Please ask about anything that is not clear.
Okay, a non-bitwise question
This is explained in the binding docs, which you have obviously read to get this far, but there is a lot in there.
There is an example there for a divide by 10 transform.
You would need to use your text editor to create a file xxx.js in the /transform folder to contain the javascript, then add a readTransform= parameter to your data Thing, which points to the JS transform filename.
You could help by showing us the complete error , showing us what you have done , like the setup of your Thing and the content of your JS file , and explaining what you are trying to do,
I know that the Modbus binding will not produce a value like ‘275 °C’ because it does not understand units at all, so i know there is something going on that you are not telling us about.
I understand there may be language difficulties here, but you are making it really difficult.
