I wonder if someone could give me a helping hand.
I would like to develop a plugin so have started by following the tutorial video by Kai.
Everything works up to the point where I want to add in a new ‘thing’ but my new plugin does not show any ‘Supported Things’ in the list.
The debug log shows the thing-types.xml being loaded and I can’t see any errors at that point. I am absolutely sure it is something blinding obvious but I cant see it for the life of me.
Any help would be very gratefully received!
My binding.xml and thing-types.xml look like :
(I had to put a space in h ttp in the below because the forum didn’t like me posting links as a new user!)
<?xml version="1.0" encoding="UTF-8"?><binding:binding id="beesnest"
xmlns:xsi="h ttp://www.w3.org/2001/XMLSchema-instance"
xmlns:binding="h ttp://eclipse.org/smarthome/schemas/binding/v1.0.0"
xsi:schemaLocation=“h ttp://eclipse.org/smarthome/schemas/binding/v1.0.0 h ttp://eclipse.org/smarthome/schemas/binding-1.0.0.xsd”>
<name>BeesNest Binding</name>
<description>This is the binding for BeesNest.</description>
<author>Stephen</author>
</binding:binding>
and
<?xml version="1.0" encoding="UTF-8"?><thing:thing-descriptions bindingId="beesnest"
xmlns:thing="h ttp://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation=“h ttp://eclipse.org/smarthome/schemas/thing-description/v1.0.0 h ttp://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd”>
<!-- Sample Thing Type -->
<thing-type id="sample">
<label>BeesNest Binding Thing</label>
<description>Sample thing for BeesNest Binding</description>
<channels>
<channel id="channel1" typeId="sample-channel"/>
</channels>
</thing-type>
<!-- Sample Channel Type -->
<channel-type id="sample-channel">
<item-type>Switch</item-type>
<label>BeesNest Binding Channel test</label>
<description>Sample channel for BeesNest Binding</description>
</channel-type>
</thing:thing-descriptions>
Thanks very much
Stephen
