You’re probably going to have to resort to a JS transformation or a rule to process these messages. For what ever reason tasmota is sending invalid JSON and the REGEX transformation probably won’t get you to where you can correct it.
That specifically? Not really. It’s standard ECMAScript 5.1 so any JavaScript tutorial on how to process strings will do. Put that into a filename.js file under $OH_CONF/transform and wrap your code un a function like the example in the docs.
(function(i) {
// Your code goes here
return value;
})(input)
