Hello Everyone,
I’m trying to create a rule for my Receiver to always start with a specific volume. Problem is, only command I can give to it is volume up or down (VU, VD, ?V via telnet)
?V gives me VOL053 or similar outputs
I came up with the following logic:
var String CurrentVolume = executeCommandLine("python /etc/openhab2/scripts/pioneer.py ?V", 2000)
//var CurrentVolumeInt = Float::parseFloat(CurrentVolume.substring(4)) as Number
var CurrentVolumeInt = Integer.parseInt(CurrentVolume.substring(4))
if (CurrentVolumeInt < 55) {
var Difference = (55 - CurrentVolumeInt)
var i = 1
while ((i=i+1) < Difference) {
executeCommandLine("python /etc/openhab2/scripts/pioneer.py VU", 1000)
logInfo("","" + CurrentVolumeInt)
Basically, I check the current volume, if its lower then my desired (55) then I calculate how low, and send that many VU commands.
Its not working (obviously) and I suspect I do not properly understand how to convert the String value I get from the ?V command to an Int to do the calculations/looping
I tried to read other threads and try the things from there, as you can see from the commented line, but no luck.
I get this error on the log:
2021-01-04 17:20:16.238 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'PioneerVolume': For input string: "39 "
Any ideas what am I doing wrong here?
