Thank you very much for your contribution!
I really appreciate your help
Just some information regarding my setup:
I use Global Cache itach unit to convert ip commands to one-way IR output signals, to control my ir devices (TV, arvani soundbar, and set-top box) I use a globalcache.map file to store all the IR codes for my devices.
globalcache.items:
/* ADB Decoder */
String ADB "ADB" (FF_Living, Multimedia) { channel="globalcache:itachIR:000C1E026137:ir-m1#c1" }
/* Soundbar */
String Arvani "Arvani" (FF_Living, Multimedia) { channel="globalcache:itachIR:000C1E026137:ir-m1#c3" }
/* TV */
String Thomson "TV" (FF_Living, Multimedia) { channel="globalcache:itachIR:000C1E026137:ir-m1#c3" }
globalcahce.map:
Arvani_VolUp = 38109,1,1,341,171,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,21,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,1518,341,85,22,3810
Arvani_VolDown = 38109,1,1,341,170,22,20,22,20,22,21,22,20,22,21,22,20,22,20,22,20,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,21,22,20,22,20,22,63,22,20,22,21,22,63,22,20,22,63,22,63,22,63,22,21,22,63,22,1520,341,85,22,3810
So when I’m sending commands to global cache devices, using a rule, it will look something like this:
sendCommand(Arvani, "Arvani_VolUp")
I can’t see that this can be done using your above rule? :S
I’ll have to make a rule that sends exactly this “sendCommand(Arvani, “Arvani_VolUp”)” command X times, based on the dimmer value.
Best regards
Chris
