So I follow few tutorials, and I custom firmware my plug to Tasmota, and config it with mqtt binding.
I can turn on and off thing, now, how i can add it too google home?
Thanks for the help, always
I would answer to myself since is almost 2am and i need to sleep, well i found it
Switch Ventilador_Switch "Ventilador" [ "Switchable" ] { channel="mqtt:topic:f35424de:ventilador_switch" }
Then you should mark your own answer as “Solved”
