Use two rules in the same rules file. Rule one when the contact opens that starts the timer, and rule two when the contact closes that kills the timer.
I have a door sensor on my fridge, so that if somebody (coughthe wifecough) wedges it open I want to know after five minutes. But if it’s less than that, don’t bother me.
First, the rule to run the timer if the fridge opens:
rule "kitchen fridge open."
Item KITCHEN_FRIDGE_CONTACT changed to OPEN
logInfo("openhab","Kitchen fridge door opened. Starting timer.")
Kitchen_Fridge_Timer_Start_Time = now
KITCHEN_FRIDGE_DOOR_TIMER = createTimer(now.plusMinutes(Kitchen_Fridge_Door_Timeout))
logInfo("openhab","Kitchen fridge door timer expired. Sending email.")
Mail_Subject = "Kitchen fridge/freezer door left open!"
var long Time_Difference_In_Minutes = (now.millis - Kitchen_Fridge_Timer_Start_Time.millis) / 60000
Mail_Message = String::format ("The kitchen fridge door has been left ajar for %1$s minutes!!",Time_Difference_In_Minutes)
sendMail(Mail_Destination,Mail_Subject,Mail_Message)
KITCHEN_FRIDGE_DOOR_TIMER.reschedule(now.plusMinutes(Kitchen_Fridge_Door_Timeout))
Then a separate rule to kill the timer if the fridge shuts:
rule "kitchen door shut, kill kitchen timer"
Item KITCHEN_FRIDGE_CONTACT changed to CLOSED
logInfo("openhab","Kitchen fridge door closed. Killing timer.")
KITCHEN_FRIDGE_DOOR_TIMER.cancel
KITCHEN_FRIDGE_DOOR_TIMER = null
Mail_Subject = null
Mail_Message = null
var Timer doorTimer = null
rule "Notify on door open"
Item Door_Contact changed
if (doorTimer != null)
doorTimer.cancel()
if (Door_Contact.state == OPEN) {
doorTimer = createTimer(now.plusMinutes(5)) [|
// do notification
This works well since you only need a single rule. When the door is opened, the timer is created. If the door is closed before the timeout then the timer is cancelled. Otherwise the timer fires and you get notified.
thanks for the help
couldn’t really get my head round that !=null statement
after a lot of trial and error i got this to work for me
rule “test timer”
Item GaragePortSensor received update
if (GaragePortSensor.state == 100){timertest = createTimer(now.plusSeconds(10)) [|notifyMyAndroid("GaragePort", "ÖPPEN")]}
if (GaragePortSensor.state == 0) {timertest.cancel()}
