Hi all
I bought a Heltun Quinto relay switch to controll my roller shutters, because I like the idea to control two shutters with only one device.
Basically the module is working.
However I don’t understand how to operate in roller shutter mode correctly.
Regarding the product description, the module calculates the position and stops if the blinds are fully open/closed.
Is this only the case if I use a local (momentary) switch? (Right now I don’t have a swich connected.)
If I change relay 1 to “ON” via OPENHAB, it will never switch back to OFF once the blind is open/closed.
Is anyone else successfully using a Heltun Quinto?
regards
Levin
