#!/bin/bash
# run command (sudo nano ~/.bash_profile) and add this (PATH=$PATH:/home/usr/bin) without ()
# to be able to execute menu.sh from any directory
# place menu.sh file in /home/usr/bin
# replace usr with your username
# running ubuntu server 17.10 and openhabian
while true
do
clear
echo "======================"
echo "-------- Menu --------"
echo "1: OpenHAB2 Start"
echo "2: OpenHAB2 Stop"
echo "3: OpenHAB2 Status"
echo "4: OpenHAB2 Restart"
echo "5: Openhabian Config"
echo "6: Karaf Console"
echo "7: Tail Events log"
echo "8: Tail OpenHAB log"
echo "9: Backup Openhab2"
echo "10: Info"
echo ""
echo "Press any key to Quit"
read answer
case "$answer" in
1) clear
echo "Starting OpenHAB2..."
sudo systemctl start openhab2.service
2) clear
echo "Stopping OpenHAB2..."
sudo systemctl stop openhab2.service
echo "Stopped"
3) clear
echo "Status OpenHAB2"
sudo systemctl status openhab2.service
4) clear
echo "Restarting OpenHAB2..."
sudo systemctl restart openhab2.service
echo "Restarted"
5) echo "Openhabian Config"
sudo openhabian-config
6) echo "OpenHAB Karaf Console"
openhab-cli console
7) echo "Tailing EVENTS LOG"
tail -f /var/log/openhab2/events.log
8) echo "Tailing OPENHAB LOG"
tail -f /var/log/openhab2/openhab.log
9) echo "Are You Sure? "Y", any other key to exit "
read input
if [ "$input" != "Y" ]; then
echo "you have fat fingers"
exit
fi
if [ "$input" == "Y" ]; then
echo "Backing up OpenHAB"
sudo openhab-cli backup
fi
10) echo "Info"
sudo openhab-cli info
esac
break
done
Hi @alokin79, good idea! What are your thoughts on adding a menu like this for the cli itself? One that could be launched via openhab-cli menu
for example which would go over all of the cli commands.
I like it. Maybe the menu like this would be the default when you just run openhab-cli
. It makes the cli pretty self-documenting that way.
