Hide widget configuration parameters/props
I’m wondering if there’s a way to hide widget configuration parameters based on the value of other configuration parameters. The idea is that some parameters are only relevant if some other parameter has a certain value, and could be hidden if that’s not the case, to declutter the UI.
I’ve tried visible, show etc. with no luck. I’ve also tried to read the schema, and can’t find anything there. It might not be possible to do - I’ve even tried using an expression for the advanced setting, and it doesn’t seem to be evaluated.
I do think it would be helpful when there are lots of parameters though. Is there a way?
AFAIK, this is not possible. The config dialog is rendered with the complete parameter set.
It is the same for Item or Thing configs.
