I am using openHAB #1227 on a Raspberry Pi with Zulu Java. Over time I have seen that load has increased. I have tried to stop different bundles and the affected performance at most was the influx persistence. My Influx database i running on another server (Ubuntu 16.04 VM), that machine seems to be running without any significant load.
I haven’t setup any particular retention, (besides from autogen) - so I gues that there might be an issue here.
I plan to flush (or setup some retention) my influx database to see if that is the problem
Does anybody have any ideas of what might be the cause? I only use influx for charting. Other persistence is done with mapdb. Anything in particular I should/could check?
