HM-MOD-RPI-PCB homegear openhabian installation problem GPIO 18
Platform information:
  • Hardware: Raspberry Pi 3 Model B Rev 1.2 ARMv7l
  • OS:Raspbian GNU/Linux 12 (bookworm)
  • Java Runtime Environment: openjdk version “17.0.12” 2024-07-16
  • openHAB version:4.2.2 (Build)
Issue of the topic: please be detailed explaining your issue
(I have entered this issue in the Homegear forum but thought maybe I could get some input here as well.)
I have been using Homegear in my openhabian installation on raspbian bullseye for some time and it worked well. I use a HM-MOD-RPI-PCB on the Raspberry 3B.
I installed a latest openhabian sd-card image and selected the optional installation of Homegear in the openhabian-config menu. Further I have edited the etc/homegear/families/homematicbidcos.conf to have the defaults for the HM-MOD-RPI-PCB configured (gpio 18).
The installation reported a failure as follows
Unpacking wiringpi (2.61) over (2.61) ...
Setting up wiringpi (2.61) ...
/bin/chown: warning: '.' should be ':': ‘root.root’
Processing triggers for man-db (2.11.2-2) ...
OK
2024-10-18_11:29:00_CEST [openHABian] Setting up Homegear user account permissions... OK
2024-10-18_11:29:01_CEST [openHABian] Setting up Homegear service... FAILED (enable service)
2024-10-18_11:29:57_CEST [openHABian] Checking for default openHABian username:password combination... OK
ON attempting to start the Homegear service it fails:
 start job for unit homegear.service has begun execution.
The job identifier is 968.
Oct 18 12:00:00 openhabian rpi_init[5999]: /usr/bin/gpio: Unable to open GPIO direction interface for pin 18: No such file or directory
Oct 18 12:00:00 openhabian systemd[1]: homegear.service: Control process exited, code=exited, status=1/FAILURE
Subject: Unit process exited
Defined-By: systemd
Support: https://www.debian.org/support
An ExecStartPre= process belonging to unit homegear.service has exited.
The process' exit code is 'exited' and its exit status is 1.
The tty device seems to be ok:
$ dmesg | grep "tty"
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=60f03150-02 rootfstype=ext4 fsck.repair=yes rootwait
[    0.000416] printk: console [tty1] enabled
[    3.179306] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[    3.182302] serial serial0: tty port ttyS0 registered
[    3.255491] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.258571] printk: console [ttyAMA0] enabled
[    8.707704] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    8.736534] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    8.854399] systemd[1]: Expecting device dev-ttyAMA0.device - /dev/ttyAMA0...
$ ll /sys/class/tty/ttyAM*
lrwxrwxrwx 1 root root 0 Oct 18 11:28 /sys/class/tty/ttyAMA0 -> ../../devices/platform/soc/3f201000.serial/tty/ttyAMA0/
the default user openhabian has group membership for gpio.
What am I missing?
I would be grateful for any advice!
Best regards!
Just FYI, I tried bumping the version of openhabian config tool ( openHABian Configuration Tool — [main]{2024-10-15T10:54:03+02:00}(a85d675)) as I saw there have been some changes to the openhabian scripts for Homegear installation, which excludes wiringpi. I deinstalled homegear and wiringpi, rebooted and tried to reinstall Homegear, which failed and gave me the following status:
sudo systemctl status homegear
× homegear.service - Homegear
     Loaded: loaded (/etc/systemd/system/homegear.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Fri 2024-10-18 14:59:16 CEST; 21min ago
    Process: 1106 ExecStartPre=/usr/local/sbin/rpi_init /usr/bin/gpio export 18 out (code=exited, status=127)
Hi Vincent, I ran into the same problem: Updated a pi4 from buster to bookworm/oh4 and Busware SCC.
It seems that the GPIO management has changed with the OS-update as there is no directory /usr/bin/gpio anymore.
Did you find a solution meanwhile?
$ journalctl -xeu homegear.service
May 10 21:12:27 openhab rpi_init[1787]: /usr/local/sbin/rpi_init: line 5: /usr/bin/gpio: No such file or directory
$ systemctl status homegear.service
**x** homegear.service - Homegear
Loaded: loaded (/etc/systemd/system/homegear.service; **enabled**; preset: **enabled**)
Active: **failed** (Result: exit-code) since Sat 2025-05-10 21:12:27 CEST; 13h ago
Process: 1787 ExecStartPre=/usr/local/sbin/rpi_init /usr/bin/gpio export 18 out **(code=exited, status=127)**
CPU: 18ms
May 10 21:12:27 openhab systemd[1]: Starting homegear.service - Homegear...
May 10 21:12:27 openhab systemd[1]: **homegear.service: Control process exited, code=exited, status=127/n/a**
May 10 21:12:27 openhab systemd[1]: **homegear.service: Failed with result 'exit-code'.**
May 10 21:12:27 openhab systemd[1]: **Failed to start homegear.service - Homegear.**
In the pertaining directory are lots of other executables though:
$ ls -l /usr/bin/gpio*
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpiodetect
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpiofind
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpioget
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpioinfo
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpiomon
-rwxr-xr-x 1 root root 67160 Sep 21  2021 /usr/bin/gpioset
I probably need to read the man pages and change the /usr/local/sbin/rpi_init file
Can anyone help?
Best regards,
Armin
