hmerk
(Hans-Jörg Merk)
October 29, 2024, 10:35pm
1
Resources
uid: hmerk:actual_energy_consumption
label: Actual energy consumption
description: Updates Items holding information of actual energy consumption
configDescriptions:
- name: persistenceService
type: TEXT
context: text
label: Persistence Service
description: Persistence service used to store information
limitToOptions: true
options:
- label: default
value: default
- label: RRD4J
value: rrd4j
- label: MapDB
value: mapdb
required: true
- name: groupItem
type: TEXT
context: item
label: Equipment Group Item
description: Equipment Group Item
required: true
triggers:
- id: "1"
configuration:
itemName: "{{groupItem}}_MeterValue"
conditions: []
actions:
- inputs: {}
configuration:
blockSource: <xml xmlns="https://developers.google.com/blockly/xml"><block
type="oh_event" id="wR2@!=5jfQG3|Tnh{+~x" x="-18" y="-712"><field
name="eventType">postUpdate</field><value name="value"><shadow
type="text" id="jWgD4t7.O;)]3OP#c3_R"><field
name="TEXT">value</field></shadow><block type="oh_get_persistvalue"
id="o{T16a(Kz8%H}OiFX!92"><field
name="methodName">deltaSince</field><value name="itemName"><shadow
type="oh_item" id=";^(0GHJN+qNYn[-TH#fs"><mutation itemName="MyItem"
itemLabel="MyItem"></mutation><field
name="itemName">MyItem</field></shadow><block type="oh_item"
id="Tzh_y}fz^X{LSYcL)1:A"><mutation
itemName="{{groupItem}}_MeterValue" itemLabel="Meter
Value"></mutation><field
name="itemName">'{{groupItem}}_MeterValue'</field></block></value><value
name="persistenceName"><shadow type="oh_persistence_dropdown"
id="4Ip6?cO^P}fVH,;U(Ig1"><field
name="persistence">default</field></shadow><block
type="oh_persistence_dropdown" id="6jc}NQ;mmWl:(zG!(jGl"><field
name="persistence">{{persistenceService}}</field></block></value><value
name="dayInfoSince"><block type="oh_zdt_amend"
id="iD,W+1Cif+R+$PB{G9C4"><mutation items="3"></mutation><field
name="operation">with</field><value name="baseZdt"><shadow type="oh_zdt"
id=".}/;k[$7Zc)QZ#L7]?N^"><field
name="day">2023-11-06</field></shadow><block type="oh_zdt_now"
id="/1C:nps2x$!r8vhRP|j#"></block></value><value name="ADD0"><block
type="oh_zdt_temporal_unit" id="8-|B:O|.DMk.L})K80LD"><mutation
blockType="3"></mutation><field
name="value">0</field></block></value><value name="ADD1"><block
type="oh_zdt_temporal_unit" id="RKZtxH:+496e2$dQ!%8M"><mutation
blockType="4"></mutation><field
name="value">0</field></block></value><value name="ADD2"><block
type="oh_zdt_temporal_unit" id="@5]mF~iAPG:(bp:p[G$W"><mutation
blockType="5"></mutation><field
name="value">0</field></block></value></block></value></block></value><value
name="itemName"><shadow type="oh_item"
id="Pt$^PEJnHsZ}1wO!(iS%"><mutation itemName="MyItem"
id="+h(C{ZBBbQbWF0}5O-T("><mutation
itemName="{{groupItem}}_UsageToday" itemLabel="Usage
Today"></mutation><field
name="itemName">'{{groupItem}}_UsageToday'</field></block></value><next><block
type="oh_event" id="i.q{)XrqTs1%hj:3tW1h"><field
id="~Fs,0-d,f:r)/)Po0fzF"><field
type="oh_item" id="eV4}S-t^%::[S(zE:Xlf"><mutation itemName="MyItem"
id="SOrpMoT6[8q]knugKx_q"><mutation
type="oh_persistence_dropdown" id="FDP+td7ya7ZJiW/APx7q"><field
id="2*j}a1;J+ahW).NAc-?_"><mutation items="3"></mutation><field
name="day">2023-11-06</field></shadow><block type="oh_zdt_plusminus"
id="(kYEPjaai#6;X6p|dxJ4"><field name="plusminus">minus</field><field
name="period">Days</field><value name="offset"><shadow
type="math_number" id="-yJ-wrzk}kF?MBl$=Q.v"><field
name="NUM">0</field></shadow><block type="math_arithmetic"
id="(oeV|D]OsZCU.`m@)]1p"><field name="OP">MINUS</field><value
name="A"><shadow type="math_number" id="Fx+Cu7o^MycxpT3jxx+."><field
name="NUM">1</field></shadow><block type="oh_get_zdt_part"
id="UZhn],`Suu4@iT2SSiQ!"><field
name="temporalPart">getDayOfWeek</field><value name="zdt"><block
type="oh_zdt_now"
id="kC94|*Hu27vkg)had{QI"></block></value></block></value><value
name="B"><shadow type="math_number" id=";|j$B7k0jnnHvH@b+~C?"><field
name="NUM">1</field></shadow></value></block></value></block></value><value
name="ADD0"><block type="oh_zdt_temporal_unit"
id="7%H@giD-Uh9,|po3cj2A"><mutation blockType="3"></mutation><field
type="oh_zdt_temporal_unit" id="dk:_xU=_y{Mk5ff;-[sF"><mutation
type="oh_zdt_temporal_unit" id="}Py6_2W%?tn{lc||R#:D"><mutation
id="U^2/Ta?7FbQCrVTT$/6:"><mutation
itemName="{{groupItem}}_UsageWeek" itemLabel="Usage
Week"></mutation><field
name="itemName">'{{groupItem}}_UsageWeek'</field></block></value><next><block
type="oh_event" id="ekS[%nx~(};zhL!aj3cq"><field
id="iLkwL4E;@rmKIiZ6qll*"><field
id="X2hEF34^7YJOSj0$`K@r"><mutation
type="oh_persistence_dropdown" id="MP#fhHAZvlfF6G`(xA,U"><field
id="QkmniLh_:l9caOngKc%-"><mutation items="4"></mutation><field
id="Kb02Z)*92(+@lOWZOvh0"></block></value><value name="ADD0"><block
type="oh_zdt_temporal_unit" id="H*pv,lD0=!UbXKZdp`[e"><mutation
blockType="2"></mutation><field
name="value">1</field></block></value><value name="ADD1"><block
type="oh_zdt_temporal_unit" id="shEpFhjO1]LDVk{kWlv4"><mutation
type="oh_zdt_temporal_unit" id="2Qm(5K)P]t|PFTNFDHtE"><mutation
name="value">0</field></block></value><value name="ADD3"><block
type="oh_zdt_temporal_unit" id="YPczNi4E!2m`Zm]0eEDm"><mutation
id="Q7zR(dyrQ!pqzAIc8v?j"><mutation
itemName="{{groupItem}}_UsageMonth" itemLabel="Usage
Month"></mutation><field
name="itemName">'{{groupItem}}_UsageMonth'</field></block></value><next><block
type="oh_event" id=";{L95656B0OHC6ZIf9Qn"><field
id="KW|1F}!ZJpL#aZem8%[s"><field
id="d[6-:!?sti()whBdPIm6"><mutation
type="oh_persistence_dropdown" id="ZD^J(z8(zg7JMpLh4Lx2"><field
id="?[9oT3IE:*L+{@F~$(/i"><mutation items="5"></mutation><field
id="z|ebTzv5!aK$J=6?Qjk("></block></value><value name="ADD0"><block
type="oh_zdt_temporal_unit" id="Em1+}@#N3RS)w1.2ZN!Z"><mutation
blockType="1"></mutation><field
type="oh_zdt_temporal_unit" id="(Lk8ACz!])CM0H[HZODa"><mutation
name="value">1</field></block></value><value name="ADD2"><block
type="oh_zdt_temporal_unit" id="Vp+el6m7t4$S#Z.m97XJ"><mutation
type="oh_zdt_temporal_unit" id="Nmp.vDAE!1zJI-r!LW+."><mutation
name="value">0</field></block></value><value name="ADD4"><block
type="oh_zdt_temporal_unit" id="9,z(iAJd=|VL98uHq$_,"><mutation
id="n0#(pT9Uj$D.G9qpYSf@"><mutation
itemName="{{groupItem}}_UsageYear" itemLabel="Usage
Year"></mutation><field
name="itemName">'{{groupItem}}_UsageYear}}'</field></block></value><next><block
type="oh_event" id="c)`^`GpeCp)rQf3{pKLq"><field
id="~/A/N.nVj]EIak,;a#LL"><field
id="MeG%yL]#$Poq~}yMXxi;"><mutation
type="oh_persistence_dropdown" id="2hPNgWokiMplnWPc@fDy"><field
name="dayInfoSince"><block type="oh_zdt_fromText"
id="Yi{o9`Uv!L[sTXWKzH%s"><value name="day"><shadow type="text"
id="%HAh{g{;*ad]1^jZVpn("><field
name="TEXT">2023-08-19</field></shadow><block type="oh_getitem_state"
id="#SNHcwEDkwgxVvQEncs+"><value name="itemName"><shadow type="oh_item"
id="`)F90,]i,zF0!^MTlPjh"><mutation itemName="MyItem"
id="Qa|FV[|k3D.`.c}b7|CX"><mutation
itemName="{{groupItem}}_ReadingDate" itemLabel="Start date of billing period"></mutation><field
name="itemName">'{{groupItem}}_ReadingDate'</field></block></value></block></value></block></value></block></value><value
id="QCMA}5ELYGMsf6F4c4yu"><mutation
itemName="{{groupItem}}_UsageBillingCycle"
itemLabel="Usage in actual billing period"></mutation><field
name="itemName">'{{groupItem}}_UsageBillingCycle'</field></block></value></block></next></block></next></block></next></block></next></block></xml>
type: application/javascript
script: >
items.getItem('{{groupItem}}'+'_UsageToday').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince((time.ZonedDateTime.now()).withHour(0).withMinute(0).withSecond(0),
'{{persistenceService}}')?.numericState));
items.getItem('{{groupItem}}'+'_UsageWeek').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusDays((((time.ZonedDateTime.now()).dayOfWeek().value()) - 1)).withHour(0).withMinute(0).withSecond(0), '{{persistenceService}}')?.numericState));
items.getItem('{{groupItem}}'+'_UsageMonth').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince((time.ZonedDateTime.now()).withDayOfMonth(1).withHour(0).withMinute(0).withSecond(0), '{{persistenceService}}')?.numericState));
items.getItem('{{groupItem}}'+'_UsageYear').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince((time.ZonedDateTime.now()).withMonth(1).withDayOfMonth(1).withHour(0).withMinute(0).withSecond(0), '{{persistenceService}}')?.numericState));
items.getItem('{{groupItem}}'+'_UsageBillingCycle').postUpdate((items.getItem('{{groupItem}}'+'_MeterValue').persistence.deltaSince(time.toZDT(items.getItem('{{groupItem}}'+'_ReadingDate').state), '{{persistenceService}}')?.numericState));
type: script.ScriptAction
hmerk
(Hans-Jörg Merk)
October 29, 2024, 11:22pm
2
@stefan.hoehn Could you please have a look at this template.
It creates a working script part, but the “since” definition is not shown in Blockly …
To be honest, I have no experience with templates. What I did though, I created a blockly rule and pasted your xml into the block part. This created the following blocks
and from there the following code was created:
items.getItem('{{groupItem}}_UsageToday').
postUpdate((items.getItem('{{groupItem}}_MeterValue').
persistence.deltaSince(time.ZonedDateTime.now().minusHours(1))?.numericState));
items.getItem('{{groupItem}}_UsageWeek').postUpdate((items.getItem('{{groupItem}}_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusHours(1))?.numericState));
items.getItem('{{groupItem}}_UsageMonth').postUpdate((items.getItem('{{groupItem}}_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusHours(1))?.numericState));
items.getItem('{{groupItem}}_UsageYear').postUpdate((items.getItem('{{groupItem}}_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusHours(1))?.numericState));
items.getItem('{{groupItem}}_UsageBillingCycle').postUpdate((items.getItem('{{groupItem}}_MeterValue').persistence.deltaSince(time.ZonedDateTime.now().minusHours(1))?.numericState));
which seems to be correct, doesn’t it?
If you are using a template and it doesn’t work there, you probably have to file a bug because I first need to get acquainted how templates actually work to try to figure out what the issue is.
What I know is that behind the scenes, this is a complex block that uses so called mutators which dynamically decide what is allowed and what not, so it might go together with the issue you encounter.
hmerk
(Hans-Jörg Merk)
October 30, 2024, 9:27am
4
stefan.hoehn:
Yes, the script code is correct, but the Blockly rendering isn’t. The “since” part is completely wrong (empty) and therefore not changeable.
This is, what it should look like:
I will open a detailed issue / bug report on git.
How about a making a joint call session?
hmerk:
?.numericState
We found the problem: one of the blocks had a wrong name: dayInfo instead of the new name dayInfoSince
hmerk
(Hans-Jörg Merk)
October 30, 2024, 5:04pm
8
Thanks for the joint session @stefan.hoehn !!
For others : we could identify the issue within the blockly code. The template was created before “dayInfo” was changed to “dayInfoSince”. After editing the test template, everything was fine.
I am going to edit my originnal templates to make them working again.
I will close this topic and remove the published tag.
