- Platform information:
- Hardware: RAspberry PI (3)
- OS: Home Assistant
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic:
I have been trying to get my Sonoff set up with Home assistant using Tasmota.
I have managed to get my Sonoff switch flashed with Tasmota and set up my Raspberry Pi with Home Assistant / HassIO. Both seem to work fine. However, I can’t seem to get the MQTT to connect the sonoff device without getting this message;
1570126574: New connection from 192.168.1.92 on port 1883.
1570126574: Socket error on client , disconnecting.
MQTT on the sonoff is setup as follows;
and the MQTT is the HA Configurator is;
Broker: 192.168.1.91
Port: 1883
Username: test
Password: password
What am I missing?
Thanks in advance for any help. If you need anymore information just let me know
