Hi @mjeshurun,
thanks for willing to test and help.
Committing logs and feedback for 2., 4. and 5. would be great.
Thanks,
Jonas
Hi @mjeshurun,
Thanks,
Jonas
Cool. Iāll reply again once I receive the devices and we can continue with testing.
All the best till then
Iāve updated the installation guide. It would be great if you could read and check it before I will create a Pull-Request for the official code repository.
Current binding download: org.openhab.binding.homeconnect-2.5.0.201909041200.jar
Thanks,
Jonas
Hi Jonas,
I finally had some time to test!
The item discovery went well, but when I tried to configure them via filebase config I had :offline.log (35.8 KB)
and 10 error resulted in:
2019-09-05 21:00:35.049 [ERROR] [dler.AbstractHomeConnectThingHandler] - Could not fetch available programs. Communication error! response code: 429, message: Too Many Requests, body: {
āerrorā: {
ākeyā: ā429ā,
ādescriptionā: āThe rate limit ā10 successive error calls in 10 minutesā was reached. Requests are blocked during the remaining period of 581 seconds.ā
At this moment, it works again, no idea what went wrongā¦
I just turned on and off the hood via openhab! whow
About two weeks of homeconnect log. I think it is the 2.5.0.201908230845 version i tested.
homeconnect.zip .txt (156.1 KB)
I did not notice any problems, except the iDos empty notification does show up in the home connect app and i would like to get that in openHAB too.
Iām still struggling with the oven control.
Not all programs show in the binding but this seems to be a limitation of Home Connect itself.
I am wondering if other people see the same granted scopes on the home connect developer account.
Iām mostly interested why Iām missing the control options in on the oven.
Nice. Will check your log soon.
Is it possible that you send me a screenshot of your paperUI (overview)?
Hi @janser1,
Iāve noticed it too some of my tested devices. The API is not responding all available programs.
Yes, thatās normal. You need to sign an additional partner agreement to access the other scopes.
Did you tried the latest binding version? Can you start a program?
Thanks for the log file. I resolved the error in the current binding version. If the device is offline you cannot trigger commands.
Iām just wondering. According to the logs your hood has doors Maybe it was a bug I already fixed.
Just got around to setup an betahab aswell. Its compleatly standalone, and has 0 config except the homeconnect binding.
After going through the documentation you provided on the github page, it worked and managed to discover all my items. I got 5 items, so pretty quick it gave me this:
ādescriptionā: āThe rate limit ā50 calls in 1 minuteā was reached. Requests are blocked during the remaining period of 40 seconds.ā
But it did discover everything. Attatched screenshot.
Ill let this system run, so i wont be limited by the 50 calls for a while. And if you want, i can upload the logs after cooking dinner etc etc later tonight.
You have to many devices Maybe I should add a note about this problem to the documentation. āPlease only add max. 2 devices at a time due to API limitationsā¦ā
This would be really great. Thanks in advance.
Hi again. I just left it on with no items defined. So it seems like it dosent pickup any changes.
Ill create and testing .items file and see if i can get more into the logs.
but i noticed this in the log:
2019-09-13 02:25:45.531 [WARN ] [internal.client.HomeConnectApiClient] - [SIEMENS-LC97FVW60S-68A40E088F9F] SSE error: \n not found: limit=0 content=ā¦
2019-09-13 02:26:10.293 [WARN ] [internal.client.HomeConnectApiClient] - [SIEMENS-HM876GDB6S-68A40E195295] SSE error: \n not found: limit=0 content=ā¦
2019-09-13 02:27:28.390 [WARN ] [internal.client.HomeConnectApiClient] - [SIEMENS-HM876GDB6S-68A40E195295] SSE error: null
Guess the \n thingy is an bug?
Some more info. I added the hob and hood manually to an items file. (Note im at work now, so i cant interact with them āmanually.ā) Will let it run for a day too fetch some data.
Here is my items file:
Group gHC "Home Connect" <whitegood>
// Siemens Ventilator (SIEMENS-LC97FVW60S-68A40E088F9F - Home Connect connected kitchen hood.
Group gHChood "Siemens Ventilator" <fan> (gHC)
Switch HPowerState "Power State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:power_state" }
String HOperationState "Operation State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:operation_state" }
Switch HRemoteStartAllowanceState "Remote Start Allowance State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:remote_start_allowance_state" }
Switch HRemoteControlActiveState "Remote Control Activation State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:remote_control_active_state" }
Switch HLocalControlActiveState "Local Control Activation State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:local_control_active_state" }
String HActiveProgramState "Active Program State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:active_program_state" }
String HSelectedProgramState "Selected Program State" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:selected_program_state" }
String HVentingLevel "Venting Level" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:hood_venting_level" }
String HIntensiveLevel "Intensive Level" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:hood_intensive_level" }
String HBasicActionState "Program actions" (gHChood) { channel="homeconnect:Hood:SIEMENS-LC97FVW60S-68A40E088F9F:basic_actions_state" }
// Siemens Platetopp (SIEMENS-EX877LYV1E-68A40E1BD6A8) - Home Connect connected kitchen cooktop (hob)
Group gHChob "Siemens Platetopp" <kitchen> (gHC)
Switch PPowerState "Power State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:power_state" }
String POperationState "Operation State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:operation_state" }
Switch PRemoteStartAllowanceState "Remote Start Allowance State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:remote_start_allowance_state" }
Switch PRemoteControlActiveState "Remote Control Activation State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:remote_control_active_state" }
Switch PLocalControlActiveState "Local Control Activation State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:local_control_active_state" }
String PActiveProgramState "Active Program State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:active_program_state" }
String PSelectedProgramState "Selected Program State" (gHChob) { channel="homeconnect:Hob:SIEMENS-EX877LYV1E-68A40E1BD6A8:selected_program_state" }
Right away i got an error in the log:
2019-09-13 09:48:47.114 [ERROR] [dler.AbstractHomeConnectThingHandler] - API communication problem while trying to update SIEMENS-EX877LYV1E-68A40E1BD6A8!
org.openhab.binding.homeconnect.internal.client.exception.CommunicationException: Communication error! response code: 409, message: Conflict, body: {
"error": {
"key": "SDK.Error.UnsupportedStatus",
"description": "Status not supported"
} (Tried at Fri Sep 13 09:48:47 UTC 2019)
at org.openhab.binding.homeconnect.internal.client.HomeConnectApiClient.checkResponseCode(HomeConnectApiClient.java:861) ~[?:?]
at org.openhab.binding.homeconnect.internal.client.HomeConnectApiClient.checkResponseCode(HomeConnectApiClient.java:840) ~[?:?]
at org.openhab.binding.homeconnect.internal.client.HomeConnectApiClient.getData(HomeConnectApiClient.java:691) ~[?:?]
at org.openhab.binding.homeconnect.internal.client.HomeConnectApiClient.getStatus(HomeConnectApiClient.java:607) ~[?:?]
at org.openhab.binding.homeconnect.internal.client.HomeConnectApiClient.isRemoteControlStartAllowed(HomeConnectApiClient.java:322) ~[?:?]
at org.openhab.binding.homeconnect.internal.handler.AbstractHomeConnectThingHandler.lambda$28(AbstractHomeConnectThingHandler.java:528) ~[?:?]
at org.openhab.binding.homeconnect.internal.handler.AbstractHomeConnectThingHandler.updateChannel(AbstractHomeConnectThingHandler.java:318) ~[?:?]
at org.openhab.binding.homeconnect.internal.handler.AbstractHomeConnectThingHandler.handleCommand(AbstractHomeConnectThingHandler.java:120) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:229) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Here is the output from all the defined vars:
root@betahab:/etc/openhab2/misc# grep 'String\|Switch' ../items/homeconnect.items | awk '{print $2}' | while read line; do printf "Var: $line\t\t"; curl -s http://localhost:8080/rest/items/$line/state;echo ; done
Var: HPowerState OFF
Var: HOperationState Inactive
Var: HRemoteStartAllowanceState ON
Var: HRemoteControlActiveState ON
Var: HLocalControlActiveState OFF
Var: HActiveProgramState NULL
Var: HSelectedProgramState NULL
Var: HVentingLevel NULL
Var: HIntensiveLevel NULL
Var: HBasicActionState NULL
Var: PPowerState OFF
Var: POperationState Inactive
Var: PRemoteStartAllowanceState NULL
Var: PRemoteControlActiveState ON
Var: PLocalControlActiveState OFF
Var: PActiveProgramState NULL
Var: PSelectedProgramState Cooking.Hob.Program.PowerLevelMode
Will let it run now for a while, and then i can upload the logs.
I didnt bother too add the appliences that i know already use. Like dishwasher and ovens. I can if you want me too.
Sorry for the long post!
-torgrim
Its a Bosch PXV975DV1E cook top/hob.
I tried to investigate with my home connect developer account if their are more channels available.
But I canāt seem to get the physical device simulator to work with my devices?
Especially the current power level(s) are āneededā . So I can turn on or adjust the hood (different brand with 433 Mhz remote (using rfxcom binding).
I also tested your latest version of the binding and it still works fine. I think its ready for a PR to get It in the official repo.
I did split the 6 home devices now on 3 separate applications on the dev portal and as such I did create 3 API bridges. Now it looks like itās working. Hereās my list of appliances:
Iāll try it out now for some time and see how it will work and get back to you if something might not be working as expected.
Can you send me your log. I will have a look.
PR is on its way
