Home Connect binding
When your machine is ON, the thing should be ONLINE and you should not have a request run every 30 minutes.
This is working like that in my case.
Jonas is able to reproduce your problem and is working on an improvement. When the authorization token will expire (every 24h), the binding will retry the connection but with a lower frequency. It should avoid overriding the rate limit.
It takes age to test as you have to wait at best 24h to see if it works as expected.
I installed openhab 3.1.0m5 today and now the binding doesn’t start anymore,
2021-06-03 17:43:41.234 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.homeconnect-3.1.0.202105061017-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.homeconnect [310]
Unresolved requirement: Import-Package: com.sun.jdi; resolution:=ā€œoptionalā€
Unresolved requirement: Import-Package: com.sun.jdi.connect; resolution:=ā€œoptionalā€
Unresolved requirement: Import-Package: com.sun.jdi.event; resolution:=ā€œoptionalā€
Unresolved requirement: Import-Package: com.sun.jdi.request; resolution:=ā€œoptionalā€
Unresolved requirement: Import-Package: javax.measure; version=ā€œ[1.0.0,2.0.0)ā€
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:440) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.8]
I tried to remove it clear the cache and installed it again.
The binding is now part of OH. No need to use an old jar file.
I just want to report that on OH 3.1.0.M5 the stock binding works perfectly for me. I would like to thank @jb4711 for the tremendous efforts to get this binding officially adopted into OpenHAB. Great work, thank you!
I prepared an enhancement to add 9 channels for washer appliance: pre-wash, soaking, rinse plus, less ironing, program energy, program water, …
I am almost sure some of them could be applied to a washerdryer appliance. Is there someone with a washerdryer here ? In this case, please show the result when clicking on ā€œSelected Programā€ from the special binding UI page (section ā€œAppliancesā€).
Which one is lowest Version where it’s included?? I’m currently on 3.1.0M3 because other Bindings stop working since M4 :-/
It is first included in 3.1M5.
Hi @mironto, hi @stefan13,
I’ve found the cause of the problem and fixed it ([homeconnect] Fix invalid authorization header during Server-Sent Events (SSE) client creation by bruestel Ā· Pull Request #10848 Ā· openhab/openhab-addons Ā· GitHub). The fix will be merged soon.
In the meantime you could install it manually.
2021/06/15
3.0.x / 3.1.0
Download 3.0.x: org.openhab.binding.homeconnect-3.1.0.202106151528-for-3.0.2.jar
Download 3.1.0-SNAPSHOT: org.openhab.binding.homeconnect-3.1.0.202106151533-for-3.1.0-SNAPSHOT.jar
Change log:
  • Fix SSE reconnection problem
Thanks for the fix. I downloaded it into /usr/share/openhab/addons/ and chowned to openhab, but I get an error
2021-06-16 15:08:00.320 [ERROR] [al.factory.HomeConnectHandlerFactory] - bundle org.openhab.binding.homeconnect:3.1.0.202106151533 (254)[org.openhab.binding.homeconnect.internal.factory.HomeConnectHandlerFactory(301)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
        at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
        at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
        at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
        at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
        at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.200.jar:?]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.200.jar:?]
        at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
        at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.200.jar:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
2021-06-16 15:08:00.698 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.M5 (166)[org.openhab.core.config.discovery.internal.PersistentInbox(107)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=506, service.bundleid=254, service.scope=bundle, component.name=org.openhab.binding.homeconnect.internal.factory.HomeConnectHandlerFactory, component.id=301}
2021-06-16 15:08:00.702 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.M5 (166)[org.openhab.core.config.discovery.internal.PersistentInbox(107)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=506, service.bundleid=254, service.scope=bundle, component.name=org.openhab.binding.homeconnect.internal.factory.HomeConnectHandlerFactory, component.id=301} for reference ThingHandlerFactory
2021-06-16 15:08:00.710 [ERROR] [al.factory.HomeConnectHandlerFactory] - bundle org.openhab.binding.homeconnect:3.1.0.202106151533 (254)[org.openhab.binding.homeconnect.internal.factory.HomeConnectHandlerFactory(301)] : Error during instantiation of the implementation object
Do I need to uninstall the bundled 3.1.0M5 binding, first?
yes, you need to uninstall it first. not sure if the latest snapshot-version works on 3.1.0M5.
I uninstalled the binding on 3.1.0M5 and copied the snapshot version in the add-on folder - so far everything seems to work.
Will keep you updated in case of problems.
Thanks a lot for the updated version :slight_smile:
Hi.
I am running into the ā€œThe rate limit ā€œ1000 calls in 1 dayā€ was reachedā€ daily and therefore just upgraded to the 3.1.0M5 version posted here.
I am running four appliances (oven, dishwasher, coffee machine, fridge) through one web-app.
Is it still recommended to add multiple bridges connecting to single apps or how should I proceed?
I’d love to find a resolution becaus the binding is really helpful for me.
You only need to add one bridge. The binding itself throttles the request to meet the requirements by the Home Connect API. The current snapshot version posted here should work. I think the fix will be merged soon and available in the official repository.
Ok. So I’ll wait if it works tomorrow. I just created 4 bridges; each connected to one app / one device. At least 3 are working for the moment. :slight_smile:
As a side-note. Is it in general possible to add a channel ā€œOnlineā€ to the Bridge-object? This would help adding it’s state and using it in the frontend to quicker identify issues or gray out some options/devices.
I updated OH from 3.0.2 (with prerelease version of this binding) to 3.1.0. Before the first start, I removed the prerelease binding from the addons folder.
After start of OH 3.1.0, the home connect API thing is not working (status UNINITIALIZED).
Is this expected? Do I need to recreate everything?
Thanks!
Hi @sidamos,
I think you need to add the binding via UI first. After that you need to reauthenticate the binding via http(s)://your-ip-of-openhab:port/homeconnect.
Thank you for the quick answer! You are right, it is working now. :slight_smile:
Hi, i bought a new homeconnect-washer and want to use it with this binding in my openhab 2.5 installation.
Can is use the installation in paper ui or do i have to install the binding manually from first post - to get the latest version?
Can i make a guest-network (wireless) for only my washer and will this work with the binding or is it a ā€œmust haveā€ to have both (openhab server and washer) in the same network?
This is not working with direct-connection from openhab to the washer? It only works with the homeconnect cloud service? So no internetconnection - no status updates - right? So i can put the washer in a separated network and it will work?
Hi all
I have one bridge and one device (a Siemens washer) but I still hit the 429 error today.
I use 3.1.0.M5, so from the descriptions above I understood that the Binding should take care not to exceed the API limits.
Anything I can do?
In the logs, I see a keep_alive roughly every minute, but they don’t have a URI so I assume these do not count against the limit. During a washing program, a few calls are made for RemainingProgramTime or ProgramProgress, but that does not account for 1000 calls.
Thanks for any hints.
Use the final 3.1 version. I believe something was fixed regarding 429 error.
