Home Consumption - Card from ScrewPlate
A card to show electricity, gas and water consumption.
In the initial view, only the House box is displayed and if you then select the respective items, the other boxes are displayed accordingly. The animation of the individual paths should also run in the corresponding direction or not be displayed if nothing consumed.
ScrewPlate will be a template set with various widgets, all of which are highly customizable in a unified style. More information on GitHub
Screenshots
Changelog
In each widget there is a tag with version, please always make sure to use the latest version.
Change and further information on GitHub
Resources
https://raw.githubusercontent.com/DrScr3w/ScrewPlate/refs/heads/main/templates/Card_Template_Home_Consumption.yaml
