Home position
Is it possible to get the value of
PaperUI->Configuration->System->Regional Settings->Location within a rule?
@5iver is reccomending JSR223 :slight_smile:
If you don’t want to use JSR223, you could set up a dummy Item and store the location data there.
I have to move my stuff over to JSR223 also… very powerful:
i) GitHub - openhab-scripters/openhab-helper-libraries: Scripts and modules for use with openHAB
ii) GitHub - yfaway/openhab-rules: OpenHab rules for my home
Check out the gpstracker binding. I didn’t see a direct way of accessing that but reading the example configs & playing with the possibilities should get you closer to your goal which probably isn’t the location itself but rather something like a distance from home.
