I’m planning to build my alarm around OphenHab2.
Here is my project. Any remarks will be welcome.
I want to have a solution which can alert me even when electricity is cut.
It’s build around my Raspberry Pi, Aeotec Z-Stick Gen 5 ZW090 and 4 Aeotec MultiSensor 6 ZW100.
Looks good to me, for sure you have backup batteries on all your sensors as well? Do you get a notification when the battery levels of the sensors are low?
I suggest to buy one of those, too: https://www.gsm-one.de/index.php?page=categorie&cat=9
You get a notification if there´s a power cut and can also monitor humidity and temperature. Otherwise you will never know when and how long you´re running on battery. Nice side effect: you can completely switch the power socket off via SMS, i use this for resets when my router isn´t responding and i´m not at home
