Homebridge doesn`t show items of openhab2
Hi, i just spent days to resolve my homebridge problem, but it won`t work. I followed this manual https://www.npmjs.com/package/homebridge-openhab. After startup i receive this message with “sudo systemctl status homebridge”:
● homebridge.service - LSB: Start daemon at boot time
   Loaded: loaded (/etc/init.d/homebridge)
   Active: active (exited) since Sun 2017-09-03 13:55:41 CEST; 1min 26s ago
  Process: 620 ExecStart=/etc/init.d/homebridge start (code=exited, status=0/SUCCESS)
After that i have to start manually “homebridge”, then homembridge is visible within Homekit, but without any items of openhab.
[9/3/2017, 2:22:50 PM] Loaded plugin: homebridge-openhab
[9/3/2017, 2:22:50 PM] Registering platform 'homebridge-openhab.openHAB'
[9/3/2017, 2:22:50 PM] ---
[9/3/2017, 2:22:50 PM] Loaded config.json with 0 accessories and 1 platforms.
[9/3/2017, 2:22:50 PM] Loading 1 platforms...
[9/3/2017, 2:22:50 PM] [openHAB] Initializing openHAB platform...
[9/3/2017, 2:22:50 PM] [openHAB] Platform - Fetching OpenHAB devices.
[9/3/2017, 2:22:50 PM] [openHAB] Platform - Connecting to http://192.168.178.151:8080/rest/sitemaps/standard?type=json
[9/3/2017, 2:22:50 PM] Loading 0 accessories...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 031-45-154 │
[9/3/2017, 2:22:51 PM] Homebridge is running on port 51826.
My items all have tags:
Switch TV_Schlafzimmer "TV Schlafzimmer" <television> (ogSchlafzimmer) [ "Switchable" ] {mqtt=">[ mosquitto:cmnd/sonoff123/power:command:ON:1],>[mosquitto:cmnd/sonoff123/power:command:OFF:0]" }
Does anyone have an idea?
Thanks Jesco
In the service folder, the “homekit.cfg” was missing. I created manually, now the items/accessoires are all visible in Homekit.
Hi, I use Homebridge with OH2 as well.
Homebridge connects to OH and I can pair the home.app with the bridge.
RIght now I have one item in my Sitemap only, which refers to an item, which is properly tagged (worked with openhab Homekit addon before).
I created a homekit.cfg in service directory.
Does not work.
Any idea? Could you share your homekit.cfg and/or othe config (.sitemap, .items)?
Anyhow, home.app doesn’t show my item.
Thx, Bodo
I have the same problem. Homebridge with homebridge-openhab. Homebridge is connecting to openHAB but loads no items.
@jjj you said, that you created a HomeKit.cfg in the openHAB service directory. Could you tell a little bit more about it?
Hi Andrè, after I installed the Homekit Service using Paper UI, the homekit.cfg in the service folder was missing. So i created manually with these values:
org.openhab.homekit:port=9124
org.openhab.homekit:pin=031-45-154
org.openhab.homekit:useFahrenheitTemperature=false
org.openhab.homekit:thermostatCoolMode=CoolOn
org.openhab.homekit:thermostatHeatMode=HeatOn
org.openhab.homekit:thermostatAutoMode=Auto
org.openhab.homekit:thermostatOffMode=Off
org.openhab.homekit:networkInterface=10.168.178.10 //instead of localhost, i was using before
The second thing was, I created a “special” homebridge sitemap (beside my standard one). This shouldn`t have the frame labels inside!
It looks like:
sitemap homebridge label="Homebridge"{
        	Switch item=TV label="TV"
                Switch item=Stehlampe label="Stehlampe"
The last thing, don`t forget to tag your items!
Switch TV "TV" <television> (egWohnzimmer) [ "Switchable" ] {your command}
Here`s a good “howto” in german: openHAB 2 - Anbindung an HomeKit | Un*xe
As I wrote, it runs fine now. Cheers Jesco
Hi Jesco,
I think, that you are now using Homekit Service installaed from Paper UI. You don’t need homebridge anymore. Or are you able to configure rollershutters?
Cheers, André
