openHAB (1.8.1) run with Homegar / Homatic with CUL (CUL_V3 V 1.66 CUL868) on /dev/ttyACM0 nice.
I need FS20 (KSE) Device include.
I have install FS20-Binding ( FS20 Binding · openhab/openhab1-addons Wiki · GitHub) and set the rights to all:
crwxrwxrwx 1 homegear dialout 166, 0 Apr 5 19:26 /dev/ttyACM0
It is possible two bindings use the same /dev/ttyACM0 ?
Or there is a bug in FS20 Binding?
This is the error which always comes:
[ERROR] [.o.b.fs20.internal.FS20Binding:81 ] - Can't open cul device
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:269) ~[na:na]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.open(AbstractCULHandler.java:154) ~[na:na]
at org.openhab.io.transport.cul.CULManager.createNewHandler(CULManager.java:170) ~[bundlefile:na]
at org.openhab.io.transport.cul.CULManager.getOpenCULHandler(CULManager.java:89) ~[bundlefile:na]
at org.openhab.binding.fs20.internal.FS20Binding.getCULHandler(FS20Binding.java:78) [bundlefile:na]
at org.openhab.binding.fs20.internal.FS20Binding.updateDeviceSettings(FS20Binding.java:72) [bundlefile:na]
at org.openhab.binding.fs20.internal.FS20Binding.updated(FS20Binding.java:200) [bundlefile:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
Caused by: gnu.io.NoSuchPortException: null
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) ~[na:na]
at org.openhab.io.transport.cul.internal.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:244) ~[na:na]
... 8 common frames omitted
