Homegear not running on openhabian 5.0
  • Platform information:
    • Hardware: RPi4
    • OS: Openhabian
    • openHAB version: 5.0
I am currently set up a fresh installation of Openhabian (Stable).
During installation, I installed Homegear (not checked if it was running at that time).
After other configuration steps of things, rules and items, I`m reaching the time to get the Homematic sensor configured. Added the binding and the Bridge Thing… Offline (ConnectionExeption: Connection refused).
so I thought I forgot homegear installation and used openhabian-config to install it… This ends in an Error.
journalctl -xeu homegear.service
shows me:
░░ Subject: A start job for unit homegear.service has begun execution
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit homegear.service has begun execution.
░░ The job identifier is 1966.
Okt 29 20:10:44 openhab rpi_init[22446]: /usr/local/sbin/rpi_init: Zeile 5: /usr/bin/gpio: Datei oder Verzeichnis nicht gefunden
Okt 29 20:10:44 openhab systemd[1]: homegear.service: Control process exited, code=exited, status=127/n/a
░░ Subject: Unit process exited
░░ An ExecStartPre= process belonging to unit homegear.service has exited.
░░ The process' exit code is 'exited' and its exit status is 127.
Okt 29 20:10:44 openhab systemd[1]: homegear.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit homegear.service has entered the 'failed' state with result 'exit-code'.
Okt 29 20:10:44 openhab systemd[1]: Failed to start homegear.service - Homegear.
░░ Subject: A start job for unit homegear.service has failed
░░ A start job for unit homegear.service has finished with a failure.
░░ The job identifier is 1966 and the job result is failed.
There is no /usr/bin/gpio directory on this installation.
Does anybody able to help?
Thanks a lot
Nobody any idea?
Does informations missing?
Please help!
Thanks a lot
got the same issue while installing on raspi5 now. Did you get any further with the install? Any idea what to adjust?
Unfortunately not!
In various other Posts, it looks like it is a general problem with Homegear and Bookworm or Trixie.
BUT I cannot believe, since it seems nearly nobody hits this issue but us both… since this problem seems to exist a while now.
Not really satisfying for me.
I got it to start to by using
homegear -u homegear -g homegear -d
still not really happy. After I copied my backup into the system it doesn’t find any of the devices.
Thanks for sharing.
I am not at home currently. Will test it after return.
Cheers
