@igor Is openhab still supported? I just see up to 2.x in the website and logging in on 4M3 fails
Youâd better check the homehabit community.
Yes, openHAB is still supported, but only 3.x.x.
@johnuopini Yes, all openHAB versions are supported, including the latest. Can you upload debug logs from the support screen in the app, after authentication has failed?
Sure, done
@johnuopini Can you do it again? Restart the app before, and let connection error happen just before uploading. For some reason, there werenât any connection related logs (success or failure) in the uploaded logs.
Are you shure ?
At least the latest NewGen Version does not work with openHAB 4. We already discussed this in your community.
@hmerk Yes, on Android, openHAB integration was tested with openHAB 4.x. and it was working as expected.
iOS next-gen integrations are separate right now, where only 3.x is used in testing. However, there werenât any specific changes in APIs for 4.x, so as long as Basic Auth enabled in openHAB Settings it should work. I will check 4.x with iOS version later, and might ask you to upload debug logs.
Just gave it a test on a second iPad and can confirm, openHAB integration works with openHAB 4.0
Thankâs @igor for clarification.
