Hi, there is a deleted item show “No Response” in my home app.
And I think it makes all items also “No Response” in the home app…
Once I open the home app, the log of openhab would shows a warming:
“[WARN ] [.impl.json.CharacteristicsController] - Accessory 120947214 has no characteristics or does not exist.”
Or
[WARN ] [.impl.json.CharacteristicsController] - Accessory 120947214 has no characteristics or does not exist. Request: /characteristics?id=487154052.9,2088207293.10,2088207293.9,1449059169.9,1449059169.10,1449059169.13,1449059169.15,1449059169.11,1449059169.12,1449059169.14,120947214.10,120947214.9,642322279.9,642322279.10,472522844.9,1916129171.9,2147312273.9,136763654.10,136763654.9,992712677.9
I have try to find it out in openhab-cli console by typing command “openhab:homekit list”, the list does not contains 120947214
Is it a bug? I don’t encounter this situation in the past.
And how can I do now?
probably you are on openHAB 3.4. it has new feature to keep deleted items as sometimes they are not deleted but wrongly configured, e.g. syntax error in items file
to really delete them, you need to execute this command.
Thanks and let me know this feature… @yfre
I have tried it but it still don’t working in apple home app side.
And I even don’t see any record about 120947214 items in /jsondb/homekit.json
Btw, I have remove the bridge in home app. And I found that the pairing is not smooth as expectation. It always need to uninstall the homekit binding and then re-install it again. or change some value in the setting of homekit e.g pin/ setup id/ name of bridge…for now: after scan the qrcode and click “add it anyway”, it keeps loading “Connecting to Accessory” and timeout finally - Unable to Add Accessory (Accessory is not reachable). This situation I have encountered many time in different raspberry pi or network(home/ office)
hmm, we dont see that many reports on pairing issues in the last time.
according to logs it looks like home app terminates the connection. this is often the case if home app does not like the accessories OH sent to it.
can you try with one very simple accessory, something like a switch or simple light (without hue, brightness, etc).
the proper way to unpair:
remove “home” from home app
execute clearPairings in OH karaf
shutdown all homekit bridges like apple tv, ipad, homepod
restart iphone (especially, this steps often solves issues)
Thanks @yfre
I tried but I cannot find openHAB in _hap._tcp list.
After uninstall homekit add-ons and re-install it in OH.
And then follow your guideline, then it works Thanks
And find another issue:
I added new item (rollershutter) but the home app does not show it even I wait for 15 mins and try to trigger item/ save config of homekit setting. (In the past, it can auto detect new item or deleted item)
