OpenhabVersion 3.4
I have the following Problem i Configure the Homekit items via items file but if i made for example something wrong all item are poot in the “Standard room” and i have to start from beginning to sort all items in the Home App. Is there a way to set the rooms already from the items file or something to avoid the issue of sorting?
//Homekit
Switch Buero_Fenster_Homekit "Büro Fenster" {homekit="Switchable" , channel="mqtt:topic:Mosquitto:Buero:Fenster"}
Switch Buero_Decke_Homekit "Büro Decke" {homekit="Lighting" , channel="mqtt:topic:Mosquitto:Buero:Decke"}
Switch Buero_Stecdose_Homekit "Büro Anlage" {homekit="Switchable" , channel="mqtt:topic:Mosquitto:Buero:Steckdose"}
Rollershutter Buero_Rolladen_Seite_Homekit "Büro Rollladen Seite" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Buero:RolladenSeite"}
Rollershutter Buero_Rolladen_Links_Homekit "Büro Rollladen Links" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Buero:RolladenVorneLinks"}
Rollershutter Buero_Rolladen_Rechts_Homekit "Büro Rollladen Rechts" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Buero:RolladenVorneRechts"}
//Homekit
Switch Wohnzimmer_Fenster_Homekit "Wohnzimmer Fenster" {homekit="Switchable" , channel="mqtt:topic:Mosquitto:Wohnzimmer:Fenster"}
Switch Wohnzimmer_Decke_Homekit "Wohnzimmer Decke" {homekit="Lighting" , channel="mqtt:topic:Mosquitto:Wohnzimmer:Decke"}
Switch Wohnzimmer_Couch_Homekit "Wohnzimmer Couch" {homekit="Lighting" , channel="mqtt:topic:Mosquitto:Wohnzimmer:Couch"}
Switch Wohnzimmer_Steckdose_Homekit "Wohnzimmer Steckdose" {homekit="Switchable" , channel="mqtt:topic:Mosquitto:Wohnzimmer:Steckdose"}
//Switch Wohnzimmer_Stecdose2 "Steckdose2" (Wohnzimmer, Lights) {channel="mqtt:topic:Mosquitto:Wohnzimmer:Steckd ose2"}
Switch Wohnzimmer_Vitrine_Homekit "Wohnzimmer Vitrine" {homekit="Switchable" , channel="hue:0010:1:Vitrine:switch" }
Switch Wohnzimmer_Sideboard_Homekit "Wohnzimmer Sideboard" {homekit="Switchable" , channel="hue:0010:1:Sideboard:switch"}
Rollershutter Wohnzimmer_Rolladen_Seite_Homekit "Wohnzimmer RollLaden Seite" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Wohnzimmer:RolladenSeite"}
Rollershutter Wohnzimmer_Rolladen_Links_Homekit "Wohnzimmer RollLaden Links" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Wohnzimmer:RolladenVorneLinks"}
Rollershutter Wohnzimmer_Rolladen_Rechts_Homekit "Wohnzimmer RollLaden Rechts" {homekit="WindowCovering" , channel="mqtt:topic:Mosquitto:Wohnzimmer:RolladenVorneRechts"}
