Hi guys,
I just updated my existing OH2 installation to the newest snapshot from today (2016.11.02), all went well, I installed the bindings again with Paper UI and copied my configuration in the /conf/ folder.
The only issue was that iOS was not able to connect to the HomeKit interface of OH2 again.
So I uninstalled and reinstalled the HomeKit Binding but still no luck.
After some investigation I noticed that the openhab.log does not mention org.openhab.io.homekit being loaded or any other logging line about it.
When I click INSTALL in the Paper UI the openhab.log remains empty but Paper UI reports success for HomeKit. When I try to uninstall HomeKit in Paper UI a lot of errors are thrown in the openhab.log, it seems it was never installed and now it cannot be removed as it does not exist.
Is the HomeKit binding broken in the latest OH2 snapshot?
Please note that I have like 10 bindings installed with Paper UI, this is the only one not working.
2016-11-03 02:21:00.531 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/bundleFile
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:305)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:85)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:98)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:65)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:232)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)[:1.8.0_65]
at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)[227:org.openhab.io.homekit:2.0.0.201611022224]
at io.netty.util.concurrent.DefaultPromise.setSuccess(DefaultPromise.java:397)[227:org.openhab.io.homekit:2.0.0.201611022224]
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:151)[227:org.openhab.io.homekit:2.0.0.201611022224]
at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137)[227:org.openhab.io.homekit:2.0.0.201611022224]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/bundleFile (Datei oder Verzeichnis nicht gefunden)
at java.util.zip.ZipFile.open(Native Method)[:1.8.0_65]
at java.util.zip.ZipFile.<init>(ZipFile.java:219)[:1.8.0_65]
at java.util.zip.ZipFile.<init>(ZipFile.java:149)[:1.8.0_65]
at java.util.zip.ZipFile.<init>(ZipFile.java:163)[:1.8.0_65]
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:288)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
... 19 more
2016-11-03 02:21:00.546 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/com.beowulfe.hap.hap-1.1.3.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/com.beowulfe.hap.hap-1.1.3.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.558 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/com.nimbusds.srp6a-1.5.2.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/com.nimbusds.srp6a-1.5.2.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.570 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/io.netty.netty-all-4.0.32.Final.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/io.netty.netty-all-4.0.32.Final.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.582 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/javax.json.javax.json-api-1.0.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/javax.json.javax.json-api-1.0.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.593 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/net.i2p.crypto.eddsa-0.0.1-SNAPSHOT.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/net.i2p.crypto.eddsa-0.0.1-SNAPSHOT.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.605 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.bouncycastle.bcprov-jdk15on-1.51.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.bouncycastle.bcprov-jdk15on-1.51.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.616 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.glassfish.javax.json-1.0.4.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.glassfish.javax.json-1.0.4.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
2016-11-03 02:21:00.663 [ERROR] [org.openhab.io.homekit ] - FrameworkEvent ERROR - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.zeromq.curve25519-java-0.1.0.jar
Caused by: java.io.FileNotFoundException: /home/terra/openhab2/userdata/cache/org.eclipse.osgi/227/0/.cp/lib/org.zeromq.curve25519-java-0.1.0.jar (Datei oder Verzeichnis nicht gefunden)
... 19 more
