I am getting various errors in the log whenever my brightness (KNX Sensors) changes.
Is there anything i can do better to avoid this?
Thank you!
2024-03-20 10:00:01.163 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Gaestebad_Helligkeit' changed from 106.96000000000001 to 118
==> /logs/openhab.log <==
2024-03-20 10:00:02.060 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.RuntimeException: java.lang.NullPointerException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:181) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:131) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:106) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createCompletionList(ContentAssistService.java:78) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$26(LanguageServerImpl.java:581) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:458) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.completion(LanguageServerImpl.java:580) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$25(LanguageServerImpl.java:566) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$1(ReadRequest.java:66) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:246) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:237) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:232) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:49) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:1) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:264) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeAsPartOfDatatypeNode(ContentAssistContextFactory.java:264) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$1.call(ContentAssistContextFactory.java:149) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$1.call(ContentAssistContextFactory.java:1) ~[?:?]
... 4 more
Caused by: java.lang.NullPointerException
at java.util.Objects.requireNonNull(Objects.java:209) ~[?:?]
at java.lang.Class.getMethod(Class.java:2219) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:169) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:242) ~[?:?]
... 4 more
2024-03-20 10:00:02.062 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.createContextsForLastCompleteNode(ContentAssistContextFactory.java:299) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsPartOfLookahead(ContentAssistContextFactory.java:220) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:172) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:1) ~[?:?]
... 4 more
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:1) ~[?:?]`Preformatted text`
The version of openHAB is important here, because knx now supports units of measurement.
So if using openHAB4.x, a DPT9.004 will receive n.m lx, where earlier versions will receive n.m (without the unit).
An appropriate Item definition in openHAB4 would be like this:
2024-03-25 12:56:30.926 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Werkstatt_Helligkeit' changed from 0.2 lx to 6.8 lx
2024-03-25 12:56:32.196 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsAtEndOfDatatypeNode(ContentAssistContextFactory.java:230) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:161) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:1) ~[?:?]
... 4 more
... 4 more
2024-03-25 12:56:32.198 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
... 4 more
... 4 more
==> /logs/events.log <==
2024-03-25 12:56:32.498 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Wohnbereich_Helligkeit' changed from 801.9200000000001 lx to 824.96 lx
2024-03-25 12:56:33.532 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kueche_Helligkeit' changed from 467.84000000000003 lx to 500.8 lx
2024-03-25 12:56:33.555 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Essbereich_Helligkeit' changed from 909.44 lx to 930.5600000000001 lx
2024-03-25 12:56:33.864 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmer_Helligkeit' changed from 440 lx to 588.8000000000001 lx
2024-03-25 12:56:34.779 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
... 4 more
... 4 more
2024-03-25 12:56:34.781 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
... 4 more
... 4 more
