Homekit integration suddenly stopped working [SOLVED]
Hello all,
all of a sudden, my homekit integration stopped working. All items disappeared from “Home app” in all the family iPhones.
Everything else works well as usual, including cloud integration (Google Home).
I’m using AppleTV as gw, openHAB version 4.3.5 (docker, autoupdating).
Tried rebooting the AppleTV and openHAB container with no result.
Tried to add again openHAB as Homekit bridge but I get that it is already used in “another house”.
Before trying to reset all Homekit integration in Home app, I would like to check if I’m the only one having this problem at the moment. Maybe it is just a glitch or a known issue.
EDIT: forgot to add the only entry related to Homekit in openHAB log:
2025-05-08 19:41:47.926 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : ConfigurableComponentHolder configuration updated for pid org.openhab.homekit with change count 4
2025-05-08 19:41:47.928 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : Querying state active
2025-05-08 19:41:47.929 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : Querying state active
2025-05-08 19:41:47.930 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : invoking modified: modified: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2025-05-08 19:41:47.932 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : invoked modified: modified
2025-05-08 19:41:47.932 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $000: currently registered: true
2025-05-08 19:41:47.933 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $001: currently registered: true
2025-05-08 19:41:47.933 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $002: currently registered: true
2025-05-08 19:41:47.934 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $003: currently registered: true
2025-05-08 19:41:47.934 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $004: currently registered: true
2025-05-08 19:41:47.935 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $005: currently registered: true
2025-05-08 19:41:47.935 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency $006: currently registered: true
2025-05-08 19:41:47.936 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : No change in target property for dependency osgi.ds.satisfying.condition: currently registered: true
2025-05-08 19:41:47.936 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : Querying state active
2025-05-08 19:41:47.938 [DEBUG] [kit.internal.HomekitCommandExtension] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitCommandExtension(373)] : dm Homekit tracking 4 SingleStatic modified {org.openhab.io.homekit.Homekit}={port=9123, qrCode=X-HM://001408XXE4RHA, service.id=594, service.bundleid=295, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.io.homekit.internal.HomekitImpl, service.config.label=HomeKit Integration, component.id=374, service.config.factory=false, setupId=4RHA, service.config.category=io, service.config.description.uri=io:homekit, service.pid=[org.openhab.homekit, org.openhab.homekit]} (enter)
2025-05-08 19:41:47.939 [DEBUG] [kit.internal.HomekitCommandExtension] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitCommandExtension(373)] : dm Homekit tracking 4 SingleStatic modified {org.openhab.io.homekit.Homekit}={port=9123, qrCode=X-HM://001408XXE4RHA, service.id=594, service.bundleid=295, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.io.homekit.internal.HomekitImpl, service.config.label=HomeKit Integration, component.id=374, service.config.factory=false, setupId=4RHA, service.config.category=io, service.config.description.uri=io:homekit, service.pid=[org.openhab.homekit, org.openhab.homekit]} (exit)
2025-05-08 19:41:47.939 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : ImmediateComponentHolder Finished configuring the dependency managers for component for pid org.openhab.homekit
2025-05-08 19:41:47.940 [DEBUG] [nhab.io.homekit.internal.HomekitImpl] - bundle org.openhab.io.homekit:4.3.5 (295)[org.openhab.io.homekit.internal.HomekitImpl(374)] : ImmediateComponentHolder Will not enable component for pid org.openhab.homekit: holder enabled state: true, metadata enabled: true
Thank you!
Claudio
At the end I managed to find a solution: factory reset of AppleTV. That made the magic. Nothing else, no configuration change whatsoever.
Claudio
