HomeKit iOS 11 compatibility
Hi all!
My iPhone is updated to iOS 11 and I’m trying to pair it to the openHAB HomeKit service but without success.. The process has now changed so you have to enter the HomeKit code first and then it will look for the device. It was the other way around on iOS 10.
I noticed that the problem was not present when the bridge from openHAB was already connected before the update to iOS 11. But now I wanted to connect a new openHAB bridge without success.
Is there any solution to this? Is there going to be an update of some sorts?
Thanks for the reply
Greets
Ben
Solved!
Restarting openHAB solved the problem.
