Hey guys,
I have a problem with my openhab2. I updated my iPhone to iOS11 and I have no differences to iOS10 with homekit. Openhab2 Work fine but today the lights and stuff woun’t answer, so I try to reconnect openhab to homekit. It doesn’t work.
I also try to reinstall the Misc homekit and change the homekit-code, also doesn’t work.
If you have any idea to fix the problem would be fine.
Thx
I am also having the same problem i can get homekit to start connecting but it fails and says unable to connect to openhab is there a fix for this please help???
I tried now some things out to fix it. What I found out was:
The Problem was Not openHAB.
If you use an iPhone with iOS 10 and same Apple id you can use it on the iPhone with ios11
if you restart raspberry pi with openHAB you Must enter the console to reset the HomeKit pairing with the command „smarthome:homekit clearPairing“
But thats Not a real Solution
My though was that Apple use in iOS 11 HomeKit now a Software License to varify the HomeKit Produkts. Before they use a Hardware Chip for that. Thing thats make the difference.
Hi, no, this is not an ios 10 problem. With me went with ios10 so far everything perfect.
There must be a problem since iOS 11. the repairing solves not the problem to connect iOS 11 devices to openhab2 with home kit. since ios 11 there is now way to connect to opnehab 2 over home kit.
I just switched over to iOS 11 Beta 5 from latest iOS 10 and it just worked after the first boot OF iOS 11.
I did not need to reconfigure anything or reconnecting it.
I thing it isn’t a bug. Thing apple change the way to connect HomeKit devices to the system. And in IOS11 it will maybe never work with openhab2 sadly.
Guys, have there been changes to the Karaf Console lately ? When trying to do a “smarthome:homekit clearPairings” I just receive an “unknown command” error. Looking at the list of available commands, smarthome:homekit seems to be gone entirely? (Running OH2.1 stable)
Can someone please point me to the right direction?
Anyone got problems with the GM release of iOS 11? It was working for me fine after updating to iOS 11 initially, but I added a new light to my items today and it wasn’t showing up on HomeKit. I tried restarting HomeKit and my Raspberry Pi and there was no change, so I decided to remove the openHAB bridge and re-add it, now it can’t find the openHAB hub to re-add it to the app. Have apple changed how things are discovered? I noticed the “scan code” design has changed?
Can confirm that it seems impossible to pair openhab2 (OH2.1 stable) w/ homekit in iOS11 GM. Using an “old” iPad with the latest iOS 10 it worked. After it synched with iCloud openhab is now visible in iOS 11 Home.
I have no problem pairing OH:HomeKit with IOS 11. It requires a clearing of the pairing on both ends. Delete the “home” in HomeKit on the IOS side and clear the pairing on the OH side, then pair again. The problem I’m experiencing is that I have to repeat this procedure after running for some time (usually caused by disconnecting/reconnectting the IOS device from the network).
We’ll just have to see if anyone have the time and knowledge to figure it out.
