I upgrade to 16.2 some days ago - no issue.
Today I updated Home App as well - HomeKit stopped working for me with OpenHAB. Unfortunately I didn’t see this discussion before
Each time I open Home App I see the following error in the log.
] [.server.impl.connections.HttpSession] - Exception encountered while verifying pairing
java.lang.Exception: Unknown user .......
Error message changed indeed - but its still not working.
2022-12-20 21:12:38.627 [WARN ] [rver.impl.http.impl.AccessoryHandler] - Error handling homekit http request
at io.github.hapjava.server.impl.http.impl.AccessoryHandler.channelRead0(AccessoryHandler.java:53) [bundleFile:?]
at io.github.hapjava.server.impl.http.impl.AccessoryHandler.channelRead0(AccessoryHandler.java:1) [bundleFile:?]
at io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:99) [bundleFile:4.1.72.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:379) [bundleFile:4.1.72.Final]
at io.netty.channel.AbstractChannelHandlerContext.access$600(AbstractChannelHandlerContext.java:61) [bundleFile:4.1.72.Final]
at io.netty.channel.AbstractChannelHandlerContext$7.run(AbstractChannelHandlerContext.java:370) [bundleFile:4.1.72.Final]
at io.netty.util.concurrent.DefaultEventExecutor.run(DefaultEventExecutor.java:66) [bundleFile:4.1.72.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:986) [bundleFile:4.1.72.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.72.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.72.Final]
2022-12-20 21:12:38.628 [WARN ] [rver.impl.http.impl.AccessoryHandler] - Exception caught in web handler
at io.github.hapjava.server.impl.http.impl.AccessoryHandler.channelInactive(AccessoryHandler.java:46) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:262) [bundleFile:4.1.72.Final]
at io.netty.channel.AbstractChannelHandlerContext.access$300(AbstractChannelHandlerContext.java:61) [bundleFile:4.1.72.Final]
at io.netty.channel.AbstractChannelHandlerContext$4.run(AbstractChannelHandlerContext.java:253) [bundleFile:4.1.72.Final]
Well that’s no good :(. It looks like an error when the iOS device hangs up on us. Not sure why that is, though. I’ll attempt to replicate when I have a minute.
Looks like I had a compilation problem in the JAR I posted yesterday, jumping back and forth among multiple branches. Release HomeKit 2022-12-20 v1 · ccutrer/openhab-addons · GitHub. I promise this is the exact JAR I’m currently running locally. You can update to it in console with:
And yes, it’s labeled as a 4.0.0-SNAPSHOT, but that’s just cause it’s built today. It works fine in a 3.4.0 openHAB (I’m not even actually to the final release yet).
Just upgraded my HomePod mini to 16.4.
I’ve never used the “Home” App with OH, because usually after a while (not sure what the trigger was), Home couldn’t control OH items anymore. I was surprised that after the upgrade the items are now back again and can be fully controlled. Guess I’ll see whether this is just temporary or the architecture is now indeed better.
1 with ios 16.4.1 (with upgraded home architecture)
1 with ios 16.3.0
on 16.3.0 homekit addon work fine, with 16.4.1 Im unable to add openHAB bridge: after scan HomeKit QR Code from OH and waiting several minutes it fails (I noticed that it doesn’t even ask me to add the unverified accessory)
Since upgrading to 16.5 all Osram Plugs connected to Hue Bridge are not responding anymore in OH3.4.4.
Just see that also all Homematic devices are not responding anymore as well.
Does anyone has the same issue?
