Homekit Items in Instances > 1 don't show up anymore
Hello
I recognized that my homekit items from the additional bridges (i have more than 150 items) don’t show up anymore.
I get them as created in the logs when OH starts but i don’t see them on my iPhone.
They are not hidden in a room since if I filter for example for climate the temp and humidity sensors show up but only the ones from the homepod not the additional sensors i configured on bridge 3.
Is this a known bug or what else should i check?
I am running openHAB 4.3.0 Build #4407 on a Synology NAS (Docker Container).
Thank you
The issue seems to be that only one bridge is recognized in the home app.
I tried scanning the code again but i am told that the bridge is already paired (it is - but only instance 1).
Please help.
@yfre can you please look into it?
I am facing similar issue with homekit…I am interested if you found a solution!
unfortunately not. I even tried switching the bridges but every bridge instance > 1 does not show up anymore.
