Hello
Becides two docker containers (z2m and zwave-js-ui) on a 64 bit Raspi OS, I manually installed normal OH 4.1.1( no container). Everything works fine. The only point is, that homekit server does not connect to 64 bit OH.
Is there anything I have to install to get that running?
I assume you have not yet installed the Homekit add-on?
Go to Addon-Store and search for Homekit.
The addon is installed, but when I scan the pixel code, I don‘t get connected ( works on 32 bit OS)
According to the developer, homekit bundle is supported on 64bit OS and is running even faster:
Please have a look at the end of the homekit’s bundle documentation, there are some trouble shooting tips.
On a fresh OH 4.1 (64 bit ) you can link your mobile via homekit binding.
As soon as I install docker on the raspi afterwards, the homekit devices can‘t get connected to OH.
How can I solve this issue?
After two weeks of try and error I recognized that the IP address in the homekit settings was missing. I never set it on other test raspi , when there was only a single OH installation. But with docker besides the normal openhabian installation homekit doesn’t work without a specified ip address
