Hi, i recently set up openHAB. I have installed the Samsung TV binding and set up some devices and things on my network. I have also installed the HomeKit integration addon. I have an iPhone 5s and 6s to test this with. I downloaded an app called “Eve”, as the HomeKit integration GitHub said that i had to download it. I tried pairing it, almost done. Pairing fails. Tries normal Home app. Same thing. It just sits there for a minute or two, and then an error message pops up. I am using the default PIN that is set on the configure page. Basically, everything is default on the configuration for the Homekit addon. I might be doing something wrong because i just started experimenting with this. Any ideas?
