I tried to invert other window blinds I have at the house, but the change is also ignored in the Apple Home app.
Seems like I found the solution.
I had to set inversion state to false and manually add quotation marks from both sides in the code section.
value: WindowCovering
inverted: "false"
Had the same problem. Thanks for your tip @mjeshurun, that works with “”.
Thanks to @mjeshurun !
I had the same problem and gave up yesterday after several tries of different settings.
